Modellen algemeen tot +72 uur
Re: Modellen algemeen tot +72 uur
Bericht door Gert » 15-08-2017 07:42
Estofex level 2 voor het oosten van Nederland. Zie onder
.... Benelux and Germany ....
As the cold front is approaching from the west, WAA is ongoing over the level 2 area. NWP models show a low-level jet streak entering Benelux during the morning of Tuesday, increasing the LLS to 10 m/s: A broken line of multicells or a squall line with bow segments may form in Germany, producing severe to damaging wind gusts and large hail. Forecast soundings based on GFS show saturated vertical profiles over Benelux and NW Germany, high CAPE values and 15-20 m/s DLS, suggesting a potential of organized DMC with torrential rainfall with locally 40-50mm in a short period of time. Some supercells are not ruled out, with strong low-level rotation, able to produce tornadoes, mostly near the borders of Germany and the Netherlands, at the warm air regime ahead of the front. More to the south, quite fat mid-level CAPE profiles overlapping with 15-20 m/s DLS and 10-15 m/s 0-3km shear, increase the probability of large hail from more discrete cells.
QG-forcing seems rather weak but sufficient to provide widespread lift if diurnal heating is limited due to widespread cloudiness ahead of the front (SW mid-level flow is predominant). During the night, the main threat will be excessive precipitation from slowly moving thunderstorms. Some storms may reach W Poland during the night.
Laatst gewijzigd door Gert op 15-08-2017 07:42, 1 keer totaal gewijzigd.
Bericht door Gert » 28-08-2017 12:28
De woensdag ziet er zeer nat uit. Zoals gewoonlijk schuift de uitvoer nog wat maar dat het ergens in de Benelux zeer nat gaat worden lijkt mij wel duidelijk
Bericht door John » 28-08-2017 16:21
Ik ben benieuwd Gert. Het moet nog allemaal 'gemaakt' worden.
Het kan ook deels in het water vallen.
Ik zie met interesse uit naar de uitvoer morgenochtend. Dan zitten we binnen 24 uur.
Bericht door Ko » 28-08-2017 18:10
Dan zou de zomer op m'n thuisfront ipv nat nog zelfs zeer nat kunnen eindigen. En daarvoor is al niet eens zoveel meer nodig. Slechts 10 tot 15 mm gok ik.
Bericht door Gert » 29-08-2017 09:35
Op grond van de laatste uitvoer krijgt voor het noordwestelijke deel van Nederland met flink wat neerslag te maken. Modellen zijn daar tamelijk eenduidig in.
Bericht door John » 29-08-2017 12:49
Vul hier je reactie in...
Gert schreef:Op grond van de laatste uitvoer krijgt voor het noordwestelijke deel van Nederland met flink wat neerslag te maken. Modellen zijn daar tamelijk eenduidig in.
Dat is inderdaad een gegeven waarover de Guidance zich uitspreekt.
Onduidelijkheid is er nog over eventuele buienvorming woensdagmiddag in het (uiterste) zuidoosten.
Vanuit het midden van Brabant bekeken, gaan we een flink deel van de frontale neerslag over de noordwestelijke helft missen, zo lijkt het op grond van nu berekende posities.
Maar goed, we gaan het zien morgen, als de structuren zichtbaar zijn.
Laatst gewijzigd door John op 29-08-2017 16:38, 1 keer totaal gewijzigd.
Bericht door Gert » 10-09-2017 18:44
Woensdag krijgen we te maken met een kleine maar actieve depressie.aan de zuidflank kan het in Noord - Nederland weleens behoorlijk tekeer gaan even kijken hoe dit zich de komende 48 uur verder ontwikkeld.
Bericht door Gert » 12-09-2017 16:59
Code oranje voor delen van Nederland . De modellen lijken wat zindelijker te komen met het winveld
Bericht door Jaap » 12-09-2017 18:35
Zindelijker met het oog op minder gevaarlijk? Of je bedoelt zuidelijker. Leuke fout! Inmiddels verbaas ik me over de vroege herfststorm en tevens over de plaatselijk enorm natte september tot nu toe. En dat, terwijl we in mei/juni met behoorlijke droogte te maken hadden en in april nog droog en koud (later heet, eind mei al). Contrasten die we in de komende jaren ongetwijfeld vaker zullen meemaken.
Bericht door Ted » 12-09-2017 20:28
Storm wordt steeds langer. Eerst zou het erg zijn tijdens de ochtendspits. Toen tot begin van de middag. Dan tot 17 uur en nu compleet met avondspits. De duur breidt behoorlijk uit.
Morgenochtend code rood met kracht 11 of 12? Gaat het toch uit de klauwen lopen?
