Is de KNMI-lijst met hittegolven wel aangepast?
Wie weet kan iemand je helpen
Bericht door Sebastiaan » 03-07-2015 16:48
Theo Brandsma et al, hebben een tijdje terug onderzoek gedaan naar de betrouwbaarheid van de temperatuurmetingen. Zie hieronder, afgelopen winter was de discussie of het Hellmanngetal nog wel klopt. Hoe zit dat met de lijst met hittegolven? Ik kan me voorstellen dat in de oude opstelling hogere temp. werden gemeten, en dat ligt zeker bij een hittegolf natuurlijk precair. Ik vermoed dat de lijst niet is aangepast!
http://www.knmi.nl/klimatologie/lijsten/hittegolven.html
For the principal stations of KNMI in the 1901-1970 period there are two data sources available for calculating Tmean, Tn and Tx.
The first data source consists of the climatological measurements. These are available for the whole period and consist of three readings per day of a mercury thermometer and a minimum/maximum mercury thermometer at 8, 14 and 19 MLT2. Tn and Tx apply to the intervals between the observations times and are further denoted as Tn8, Tn14, Tn19, Tx8, Tx14 and Tx19. The temperature values at the remaining hours were deduced from thermograph readings. The thermograph readings were corrected towards the readings at 8, 14 and 19 MLT. Both the values of the regular thermometer and the minimum/maximum thermometer were used. As an illustration, Figure 1 shows for De Bilt the climatological means of the hourly temperatures and the several Tn and Tx values.
The second data source consists of the synoptical measurements. From 1946 onwards these measurements were done hourly at synoptic hours (1,2,…,24 UTC) mainly taken for weather forecasting purposes. First the instruments were read hourly in a Stevenson screen from a mercury thermometer but later resistance thermometers were used that could be read remotely. Till 1971, the synoptic measurements did not contain enough information to calculate 24 hour Tn Tx values for the 0-0 UTC interval.
Zie voor meer info:
Standardization of data and methods for calculating daily Tmean, Tn and Tx in the Netherlands for the 1901-1970 period
Theo Brandsma, Rudmer Jilderda and Rob Sluijter
http://www.knmi.nl/~brandsma/publications Brandsma.htm
Laatst gewijzigd door Sebastiaan op 26-07-2015 20:53, 1 keer totaal gewijzigd.
Re: Is de KNMI-lijst met hittegolven wel aangepast?
Bericht door Ted » 03-07-2015 21:00
2 punten graag:
- 1 Even in het Nederlands A.U.B.
- 2 Graag even werkende links (geen 404 meldingen).
Dank je wel!
Bericht door Edward » 03-07-2015 22:54
Sebastiaan was de http:// vergeten, dan denkt de server dat naar een lokale pagina wordt verwezen. Dit is de link: url]http://www.knmi.nl/~brandsma/publications Brandsma.htm[/url]
Het komt erop neer dat het KNMI de klimatologische en de synoptische metingen apart deed in de periode tot 1970. Het is min of meer een uitbreiding op deze tekst die in het Nederlands te vinden is en waarvan een presentatie op een VWK bijeenkomst in 2014 is geweest:
KNMI:
Klimaatdata en -advies
Gestandaardiseerde tijdreeksen
Sinds 3 maart 2014 zijn nieuwe versies van de historische temperatuurreeksen (1901-1970) van de vijf hoofdstations Den Helder, Eelde, De Bilt, Vlissingen en Maastricht beschikbaar. De etmaalextremen (minimum- en maximumtemperatuur) en het etmaalgemiddelde zijn opnieuw bepaald uit brongegevens via een gestandaardiseerde methode. In sommige gevallen zijn hierdoor dagwaarden aangepast.
In het verleden zijn diverse methoden in gebruik geweest om extremen te bepalen, hiervan zijn reconstructies gemaakt. Tussen 1951 en 1970 waren op de hoofdstations 'synoptische' en 'klimatologische' metingen gelijktijdig beschikbaar. Tot nu werd voor die periode gebruik gemaakt van synoptische metingen. Uit onderzoek is gebleken dat voor sommige stations de klimatologische metingen een hogere kwaliteit hebben dan de synoptische. Voor de nieuwe operationele tijdreeksen worden daarom in die periode de klimatologische metingen als basisgegevens gebruikt. De standaardisatie heeft de kwaliteit van de reeksen verbeterd. Vanaf 1971 zijn het klimatologische en synoptische meetnet samengevoegd en is er sprake van één meetreeks op de KNMI stations.
De reeksen zijn operationeel ingezet als onderdeel van de meetreeksen van de stations.
Laatst gewijzigd door Edward op 03-07-2015 22:54, 1 keer totaal gewijzigd.
Bericht door Sebastiaan » 04-07-2015 17:06
Link hersteld. Bedankt voor het doorgeven. Engels lijkt me geen issue. Zo wel, dan is vermoedelijk het onderwerp ook iets aan de lastige kant Afbeelding
Laatst gewijzigd door Sebastiaan op 04-07-2015 17:06, 1 keer totaal gewijzigd.
Bericht door Jaap » 04-07-2015 22:47
Een oud stokpaardje: Om een landelijke hittegolf te bepalen, zou je eigenlijk het gemiddelde van de officiële stations van het KNMI moeten nemen. Het aantal landelijke hittegolven zou dan iets afnemen, maar het geeft wel een helder beeld.
Bericht door Dick » 05-07-2015 21:57
https://en.m.wikipedia.org/wiki/Heat_wave
In Denemarken hanteren ze een definitie die mij 'eerlijker' lijkt. Voor een 'hittegolf' moet het gemiddelde maximum in tenminste 50% van het land drie dagen op rij 28 graden of hoger zijn. Ze kennen daar ook nog een 'warmtegolf' waarbij hetzelfde geldt voor gemiddeld 25 gr of hoger. In ons land zou je wel die vijf dagen op rij kunnen vasthouden en vaststellen welke stations precies worden meegenomen bij de bepaling van een landelijke hittegolf. Ik vind de introductie van een 'warmtegolf' in Nederland sowieso wel zinvol. Gewoon bij vijf zomerse dagen op rij. Dat doet recht aan het gevoel, de beleving van het grote publiek.
Laatst gewijzigd door Dick op 05-07-2015 22:25, 1 keer totaal gewijzigd.
