IJskap Antarctica
Re: IJskap Antarctica
Bericht door Gerard » 27-07-2021 23:12
WMO:
2.5.1 Louvred screens
Most of the numerous varieties of louvred screen rely on natural ventilation. The walls of such a screen should be double-louvred and the floor should be made of staggered boards, but other types of construction may be found to meet the above requirements. The roof should be double-layered, with provisions for ventilation of the space between the two layers. In cold climates, owing to the high reflectivity of snow (up to 88%), the screen should also have a double floor. At the same time, however, the floor should easily drop or tilt so that any snow entering the screen during a storm can be removed.The size and construction of the screen should be such that it keeps the heat capacity as low as practicable and allows ample space between the instruments and the walls. The latter feature excludes all possibility of direct contact between the thermometer sensing elements and the walls, and is particularly important in the tropics where insolation may heat the sides to the extent that an appreciable temperature gradient is caused in the screen. Direct contact between the sensing elements and the thermometer mounting should also be avoided. The screen should be painted both inside and outside with white, non-hygroscopic paint
https://library.wmo.int/doc_num.php?explnum_id=10616
Bericht door Gerben » 06-08-2021 20:02
Begint een beetje normaal te worden. Al 4 maanden ruim onder normaal. Komende dagen verder dalend
Bericht door Gerben » 08-08-2021 10:17
Nooit eerder gezien. Al vanaf april zeer ruim onder de normaal
Bericht door Gerben » 02-09-2021 11:03
Lokaal 20 tot 25 graden boven normaal maar blijft voor het hele gebied onder normaal. Al vanaf april op een paar dagen na.
Bericht door Gerard » 02-09-2021 22:26
Toch wel weer de koude luchtmassa boven het drijfijs, dus buiten het vasteland. Bij weinig of minder dan normaal drijfijs zal het warmer zijn rondom het vasteland. Lijkt toch veel op toegenomen afkalving.
Bericht door Gerben » 02-09-2021 22:35
Smeltseizoen is nog niet begonnen...
Afwijkingen boven het continent vallen ook wel mee. Vaak enorme afwijkingen boven het ijs. Misschien wel recorddikte. Oppervlakte kan ook nog een record worden. Alleen in 2013 en 2014 lag er meer ijs.
Adwin
Bericht door Adwin » 09-10-2021 11:25
Dan zal dit ook wel kloppen. Koudste Zuidpool winter ooit.
https://www.livescience.com/south-pole- ... ter-record
Bericht door Gerben » 10-10-2021 12:29
Adwin schreef:
09-10-2021 11:25
Laatste half jaar zelfs. Kan wel kloppen want het begon allemaal in april
https://edition.cnn.com/2021/10/09/weat ... index.html
Bericht door Karel » 12-10-2021 16:00
Adwin schreef:
09-10-2021 11:25
Met deze krachtige westelijke circulatiepatronen ook op het Noordelijk Halfrond in de komende winter wordt het bij ons een van de zachtste winters sinds 1901.
Bericht door Gerben » 12-10-2021 16:44
Karel schreef:
12-10-2021 16:00
Adwin schreef:
09-10-2021 11:25
Straalstroom was niet veel krachtiger. Ik denk eerder wat zwakker. Lag wel stukken noordelijker! Zie mijn vele posts met koud weer in Zuid Amerika en Zuid Afrika. Zelfs nu nog in Australie. Meteorologen en klimatologen letten helemaal niet...kunnen ook niks beters verzinnen. Toch krijgen zij een nobelprijs voor iets wat al lang ontdekt is.
Dat zou voor onze winter betekenen dat de straalstroom dan veel zuidelijker komt te liggen en kans op een koude winter ; )
