Zee-ijs zomer 2016
Re: Zee-ijs zomer 2016
Het wordt een 2e plek na 2012. We zitten nu qua "extent" net onder het 2007 minimum.
Het plaatje onder http://ocean.dmi.dk/arctic/icecover.uk.php is t.o.v. de melding van Gerben op 31/8/ j.l. nader gecorrigeerd.
Mazzel & broge, Evert
Heb jij een grafiek van het zeeijs bij Antarctica? Dank je
https://ads.nipr.ac.jp/vishop/#/extent
Klik op antarctic
HIeronder een korte Analyse afkomstig van Jeff Masters
Plenty of ice loss without Old Sol’s help
This summer’s polar weather didn’t fit the classic template for major ice loss, which makes the near-record depletion all the more striking and concerning. In 2007, a record-smashing minimum was achieved through weeks of round-the-clock sunshine, together with the Arctic Dipole pattern--an atmospheric setup that creates winds that compact sea ice and shove it to lower latitudes through the Fram Strait between Greenland and Norway. This year got off to a phenomenal head start, as winter temperatures north of the Arctic Circle were far higher than anything on record. Then the weather turned largely cloudy during the crucial period from late June into August, staving off what might otherwise have been a minimum even lower than 2012’s. Still, as NSIDC noted, “the upper ocean was quite warm this summer and ocean-driven melting is important during late summer.” Several weeks of intense storminess in August may have helped to churn up warmer water across the western Arctic, fostering melt from below.
“A large portion of the anomalously low ice can be attributed to the unusual winter/spring,” said Zack Labe, a Ph.D. student analyzing sea ice at the University of California, Irvine. “If we’d had a classic Arctic Dipole pattern this summer, I have no doubt we would have quickly approached or surpassed 2012.”
Vreemd dat dit zolang onopgemerkt is gebleven: Men is deze zomer rond 28 augustus met een ijsbreker naar de noordpool gevaren en men trof er open water aan...
http://www.sciencealert.com/something-terrifying-is-happening-at-the-north-pole
Vreemd dat dit het nieuws niet heeft gehaald!
Een zinnetje in het bovenvermelde bericht viel me op: de schrijver is er niet zeker van waar precies in het noordpoolgebied het ijsvrije gebied is doorvaren. Dus is het niet zeker dat het op de noordpool zelf is geweest. Misschien is dat wel de reden dat het bericht de grote nieuwsmedia niet heeft bereikt. Ik wil verder niets afdoen aan het feit dat het oppervlak en ook volume van het arctische zee-ijs afneemt, want dat is een feit en de mens is daar voor een belangrijk deel debet aan. Het zou goed zijn om duurzaamheid te betrachten en ook om daadwerkelijk CO2 uit de atmosfeer te onttrekken. Er zijn v.w.b. dat laatste interessante ontwikkelingen gaande overigens. Aan de andere kant moeten we de ontwikkelingen ook weer niet overdrijven. tijdens de afgelopen winter en lente bedroeg de extent en piomas van het zee-ijs een absoluut minimum. Velen vreesden toen dat dit jaar 2012 zou onderschrijden. Dat is niet gebeurd, omdat tijdens de afgelopen zomer de weercondities in het noordpoolgebied relatief gunstig waren.(veel lage druk en bewolking/neerslag). Later in augustus/september was er sprake van diepe stormdepressies. Het zee-ijs is dan op z'n dunst en de storm jaagt relatief warm, zout zeewater over de resterende dunne ijsplaten. Deze raken los en smelten o.i.v. het zout en het "warme" zeewater. Je kunt met evenveel gemak stellen dat als we op het laatst die 2 depressies niet hadden gehad, we boven het niveau van 2007 zouden zijn gebleven. Overigens scheelt het oppervlak gerekend met 2007 slechts 1000 km2 en is er een onzekerheidsmarge van 25.000 km2, dus helemaal zeker is het nog niet. Daarmee wil ik zeker niet aangeven dat we geen probleem hebben, maar ik plaats de feiten wel graag in de juiste context.
Hans schreef:Vreemd dat dit zolang onopgemerkt is gebleven: Men is deze zomer rond 28 augustus met een ijsbreker naar de noordpool gevaren en men trof er open water aan...
Soms treft men polynya's aan in de buurt van de Noordpool. Dat is dit jaar ook gebeurd. Je moet echter het globale plaatje bekijken. Dat is overigens duidelijk genoeg: Op langjarige tijdschaal een neerwaartse trend m.b.t. de ijsbedekking in de noordelijke poolzeeën.
Mazzel, Evert
Laatst gewijzigd door Oud-forumlid op 18-09-2016 16:14, 1 keer totaal gewijzigd.
Ted schreef:Een ding wordt vergeten. Wat nu opvalt dat de ijsaangroei na het minimum 7 tot 10 dagen eerder is begonnen.
Da's een universele logica. Het zeeijs smelt steeds noordelijker weg dus onder normale omstandigheden begint het ook eerder te groeien...
Gewoon kul dat de klimaatwereld schrijft dat zeeijs tot later smelt in september.
Misschien gaat het smelten onder het oppervlak nog door terwijl aan het oppervlak alweer ijsvorming plaats vindt, dat zou dan bij PIOMAS zichtbaar moeten zijn.
