El Niño
Re: El Niño
Deze zomer opvallend veel subtropische stormen boven een gedeelte van de Atlantische Oceaan waar relatief warm water aanwezig is.
Laatst gewijzigd door Karel op 15-08-2018 17:14, 1 keer totaal gewijzigd.
Re: El Niño
Update van Ventrice.
Another strong downwelling oceanic Kelvin wave has developed in the central Pacific. This downwelling phase is of higher amplitude of its predecessor back in Feb-Mar, which transitioned the Pacific out of La Nina.
Linear interpolation suggests this wave will make it into the eastern Pacific by January. At that time, we will likely see a rise in all Ocean based ENSO indices (i.e., ENSO 3, ENSO 3.4, ENSO 1.2).
https://twitter.com/MJVentrice/status/1032283759075360769
Re: El Niño
Sebastiaan zie ook de nieuwe analyse van de Scaife groep over de invloed van El Niño en La Niña op de Atlantische Oceaan zone in december en in februari. (volgens het Globsea model)
Ayarzagüena, B., S. Ineson, N. Dunstone, M. Baldwin, and A. Scaife, 2018:
Intraseasonal effects of El Niño Southern Oscillation on North Atlantic climate. J.
Climate. doi:10.1175/JCLI-D-18-0097.1, in press.
https://journals.ametsoc.org/doi/pdf/10.1175/JCLI-D-18-0097.1
Ook de bron van deze figuur:
Re: El Niño
http://easternmassweather.blogspot.com/2018/08/enso-coming-into-focus-for-winter-2018.html
Interessante analyse.
Dank Karel!
Dank Karel!
Re: El Niño
Table 1. Major El Niño Events Since 1950 and Their Types
Identified by the Majority Consensus From the EP/CP-Index
Laatste kolom met EP of CP is de belangrijkste ( tabel overgenomen). Daarachter fase QBO.
1 1951–52 EP EP EP EP
2 1953–54 CP CP EP CP eQBO (dalend)
3 1957–58 CP EP CP CP wQBO (afnemend)
4 1958–59 CP CP CP CP eQBO
5 1963–64 CP CP CP CP wQBO (rond de 5)
6 1965–66 CP EP CP CP eQBO
7 1968–69 CP CP CP CP eQBO
8 1969–70 CP EP EP EP
9 1972–73 EP EP EP EP
10 1976–77 EP EP EP EP
11 1977–78 CP CP CP CP wQBO (lichtjes)
12 1982–83 EP EP EP EP
13 1986–87 CP EP EP EP
14 1987–88 CP CP EP CP, wQBO
15 1991–92 CP EP CP CP wQBO
16 1994–95 CP CP CP CP, wQBO
17 1997–98 EP EP EP EP
18 2002–03 CP EP CP CP eQBO (lichtjes)
19 2004–05 CP CP CP CP deels positief, deels negatief. Rond nul
20 2006–07 EP EP EP EP
21 2009–10 CP CP CP CP, eQBO
Uit
http://agupubs.onlinelibrary.wiley.com/doi/pdf/10.1029/2012GL052483
& lees over ontwikkeling EL Nino CP winter 2019 http://www.perspectaweather.com/blog/2018/8/29/1100-am-el-nino-conditions-are-starting-to-appear-in-the-equatorial-pacific-ocean-and-its-specific-location-raises-the-prospects-for-a-cold-and-snowy-winter-in-the-eastern-us
Uit
Laatst gewijzigd door Sebastiaan op 31-08-2018 12:29, 1 keer totaal gewijzigd.
Re: El Niño
Er is een aanzet tot een El Niño geweest maar er treedt inmiddels flinke vertraging op zoals enkele jaren geleden ook gebeurde in 2014/2015.
Re: El Niño
Dank Karel!
The new ECMWF-SEAS5 guidance is in.
Takeaways:
1 El Niño: 10% neutral | 70% weak | 20% moderate
1a Modoki to start, bec. conventional
2 After a warm October, things turn in the East.
3 A stormy winter along the eastern seaboard [especially Mid-Atlantic]
https://twitter.com/BenNollWeather
Takeaways:
Re: El Niño
Deze ECMWF analyse geeft ook het hierboven door de Scaife groep gegeven El Niño beeld weer. Mogelijk geeft dat flinke afkoeling in het zeegebied aansluitend aan de Mid-Atlantic en een interessante tweede winterhelft.
Re: El Niño
https://twitter.com/WorldClimateSvc/status/1037729543002439680
De modellen zwakken de El Nino af. UKMO van 1,32 naar 0,91!
Laatst gewijzigd door Sebastiaan op 07-09-2018 10:45, 1 keer totaal gewijzigd.
Re: El Niño
Voor wie deze link nog niet kent: http://iridl.ldeo.columbia.edu/maproom/ENSO/SST_Plots/Weekly_Anomaly.html
