IJs Groenland in vier dagen vrijwel overal aan het smelten
Bericht door Gert » 25-07-2012 06:14
De titel van dit item vormde vanmorgen een kop in de Volkskrant. Het artikel is gebaseerd op onderstaande persbericht van NASA.
schreef:Satellites See Unprecedented Greenland Ice Sheet Surface Melt WASHINGTON -- For several days this month, Greenland's surface ice cover melted over a larger area than at any time in more than 30 years of satellite observations. Nearly the entire ice cover of Greenland, from its thin, low-lying coastal edges to its 2-mile-thick center, experienced some degree of melting at its surface, according to measurements from three independent satellites analyzed by NASA and university scientists.
On average in the summer, about half of the surface of Greenland's ice sheet naturally melts. At high elevations, most of that melt water quickly refreezes in place. Near the coast, some of the melt water is retained by the ice sheet and the rest is lost to the ocean. But this year the extent of ice melting at or near the surface jumped dramatically. According to satellite data, an estimated 97 percent of the ice sheet surface thawed at some point in mid-July.
Researchers have not yet determined whether this extensive melt event will affect the overall volume of ice loss this summer and contribute to sea level rise.
'The Greenland ice sheet is a vast area with a varied history of change. This event, combined with other natural but uncommon phenomena, such as the large calving event last week on Petermann Glacier, are part of a complex story,' said Tom Wagner, NASA's cryosphere program manager in Washington. 'Satellite observations are helping us understand how events like these may relate to one another as well as to the broader climate system.'
Son Nghiem of NASA's Jet Propulsion Laboratory in Pasadena, Calif., was analyzing radar data from the Indian Space Research Organisation's (ISRO) Oceansat-2 satellite last week when he noticed that most of Greenland appeared to have undergone surface melting on July 12. Nghiem said, 'This was so extraordinary that at first I questioned the result: was this real or was it due to a data error?'
Nghiem consulted with Dorothy Hall at NASA's Goddard Space Flight Center in Greenbelt, Md. Hall studies the surface temperature of Greenland using the Moderate-resolution Imaging Spectroradiometer (MODIS) on NASA's Terra and Aqua satellites. She confirmed that MODIS showed unusually high temperatures and that melt was extensive over the ice sheet surface.
Thomas Mote, a climatologist at the University of Georgia, Athens, Ga., and Marco Tedesco of City University of New York also confirmed the melt seen by Oceansat-2 and MODIS with passive-microwave satellite data from the Special Sensor Microwave Imager/Sounder on a U.S. Air Force meteorological satellite.
The melting spread quickly. Melt maps derived from the three satellites showed that on July 8, about 40 percent of the ice sheet's surface had melted. By July 12, 97 percent had melted.
This extreme melt event coincided with an unusually strong ridge of warm air, or a heat dome, over Greenland. The ridge was one of a series that has dominated Greenland's weather since the end of May. 'Each successive ridge has been stronger than the previous one,' said Mote. This latest heat dome started to move over Greenland on July 8, and then parked itself over the ice sheet about three days later. By July 16, it had begun to dissipate.
Even the area around Summit Station in central Greenland, which at 2 miles above sea level is near the highest point of the ice sheet, showed signs of melting. Such pronounced melting at Summit and across the ice sheet has not occurred since 1889, according to ice cores analyzed by Kaitlin Keegan at Dartmouth College in Hanover, N.H. A National Oceanic and Atmospheric Administration weather station at Summit confirmed air temperatures hovered above or within a degree of freezing for several hours July 11-12.
'Ice cores from Summit show that melting events of this type occur about once every 150 years on average. With the last one happening in 1889, this event is right on time,' says Lora Koenig, a Goddard glaciologist and a member of the research team analyzing the satellite data. 'But if we continue to observe melting events like this in upcoming years, it will be worrisome.'
Nghiem's finding while analyzing Oceansat-2 data was the kind of benefit that NASA and ISRO had hoped to stimulate when they signed an agreement in March 2012 to cooperate on Oceansat-2 by sharing data.
For more information about NASA programs, visit:
Ik vind het wel heel opmerkelijk nieuws. Volgens NASA komt het eens in de 150 jaar voor maar als het volgend jaar weer gebeurt............................
Laatst gewijzigd door Gert op 18-07-2014 08:40, 1 keer totaal gewijzigd.
Re: IJs Groenland in vier dagen vrijwel overal aan het smelten
Bericht door Karel » 25-07-2012 09:46
Gertv schreef:
schreef:Ik vind het wel heel opmerkelijk nieuws. Volgens NASA komt het eens in de 150 jaar voor maar als het volgend jaar weer gebeurd............................
Ja als je spannende koppen wil maken dan krijg je vaak ontsporingen. Inmiddels ook al op het NOS-journaal te zien.
Het originele bericht van NASA is hier te vinden.http://www.nasa.gov/topics/earth/features/greenland-melt.html
Volgens Jeff Masters waarnemingen sinds 1996,
'The coldest place in Greenland, and often the entire Northern Hemisphere, is commonly the Summit Station. Located at the top of the Greenland Ice Sheet, 10,552 feet (3207 meters) above sea level, and 415 miles (670 km) north of the Arctic Circle, Summit rarely sees temperatures that rise above the freezing mark. In the 12-year span 2000 - 2011, Summit temperatures rose above freezing only four times, according to weather records researcher Maximiliano Herrera. But remarkably, over the past week, temperatures at Summit have eclipsed the freezing mark on five days, including four days in a row from July 11 - 14. There are actually three weather stations located at the location--Summit, Summit-US, and Summit AWS. The highest reliable temperature measured at any of the three stations is now the 3.6°C (38.5°F) measured on Monday, July 16, 2012 at Summit-US. A 4.4°C reading at Summit in May, 2010 is bogus, as can be seen by looking at the adjacent station. Similarly, a 3.3°C reading from June 2004 is also bad. Records at Summit began in 1996.'
Eens in de 150 jaar is wel een markante uitspraak. Op 97% van Groenland smelt tussen 10 en 14 juli dit jaar is wel bijzonder. Het komt de laatste jaren meer voor dat smelt optreedt in korte periodes op meer dan 50% van Groenland.http://www1.ncdc.noaa.gov/pub/data/cmb/bams-sotc/2011/bams-sotc-2011-chapter5-the-arctic-lo-rez.pdf Opvallend is de warme rug op 500 hPa in de smeltjaren boven Groenland in de zomer.
Ook in 1889 was dat het geval volgens NASA. Een interessant jaar. Na een warme mei en juni (resp. 16,0 en 18,8 graden) volgden vier koele maanden juli, augustus, september en oktober (resp. 15,8 - 15,5 - 12,7 - 9,0) in Nederland.
De smelt was nog niet op 100% van het oppervlak van Groenland.De soundings van http://weather.uwyo.edu/upperair/sounding.html geven op de aangegeven data (10-14juli) nog temperaturen en dauwpunttemperaturen iets onder nul.
04417 Geosummit Observations at 12Z 12 Jul 2012
PRES HGHT TEMP DWPT RELH MIXR DRCT SKNT THTA THTE THTV
hPa m C C % g/kg deg knot K K K
1000.0 35
925.0 746
850.0 1498
700.0 3125
689.0 3255 -0.9 -0.9 100 5.23 55 9 302.8 318.9 303.8
688.0 3267 -0.7 -3.2 83 4.41 303.2 316.8 304.0
680.0 3360 -1.7 -2.8 92 4.60 303.1 317.3 303.9
669.0 3489 -1.1 -5.8 70 3.73 305.2 316.9 305.9
601.0 4331 -8.5 -9.5 92 3.11 306.1 316.0 306.7
593.0 4435 -6.3 -10.4 73 2.94 309.8 319.4 310.4
584.0 4555 -5.9 -11.9 63 2.64 311.6 320.4 312.1
563.0 4840 -7.3 -18.3 41 1.61 313.3 318.8 313.6
526.0 5364 -11.5 -17.5 61 1.85 314.4 320.6 314.7
Bericht door Vincent » 25-07-2012 15:37
'IJs Groenland in vier dagen vrijwel weggesmolten'
Nou, wow! Staat half NL al onder water!? Afbeelding
Bericht door Gerard » 25-07-2012 17:12
Ik werd er vanmorgen op geattendeerd door Ad Vermaas via de mail, dat er een ernstige dwaling in de berichtgeving was. Vervolgens heb ik gekeken en zag de uiteraard wat hilarische kop in de Volkskrant staan, die eigenlijk geheel niet strookt met hetgeen NASA in zijn persbericht stelde.
Het is komkommertijd veel van de betere journalisten zijn op vakantie of minder aanwezig.
Gelukkig kon ik een wetenschapsjournalist bereiken via zijn mail net voordat ik van huis weg moest. Vervolgens hebben ze het artikel rechtgezet (grotendeels). Een bedankbericht teruggestuurd gekregen.
Overigens - sneeuwbal (ex-alias van Vincent)- zouden we niet - of niet veel Afbeelding - onder water komen doordat het water vooral naar de andere zijde van de aardbol stroomt, het meeste precies naar de tegenoverliggende kant van Groenland.
N.B.
de titel van de discussie aangepast naar wat eigenlijk bedoeld was te berichten door de NASA.
Laatst gewijzigd door Gerard op 18-07-2014 08:41, 1 keer totaal gewijzigd.
Bericht door Gerard » 25-07-2012 17:16
karelvandenende schreef:De smelt was nog niet op 100% van het oppervlak van Groenland.De soundings van http://weather.uwyo.edu/upperair/sounding.html geven op de aangegeven data (10-14juli) nog temperaturen en dauwpunttemperaturen iets onder nul.
1000.0 35
925.0 746
850.0 1498
700.0 3125
Smelten kan heel goed bij een dauwpuntstemperatuur onder nul als de zon volop schijnt, wil ik er dan wel nog aan toevoegen. Vooral als de albedo flink veranderd is doordat de beschermende witte sneeuwlaag van afgelopen winter verdwenen is (door sublimatie of afsmelt) en het vuilgrijze ijs tevoorschijn gekomen is.
Bericht door Oud-forumlid » 26-07-2012 19:08
Quote uit het NASA persstukje:
schreef:'Ice cores from Summit show that melting events of this type occur about once every 150 years on average. With the last one happening in 1889, this event is right on time,' says Lora Koenig'
Nu bekroop mij hetzelfde gevoel als de lezers van het (ik mag aannemen) bekende arctische blog van Neven, en die vonden het volgende plaatje die de 150 jaar in context plaatst.Afbeelding
Elk groen streepje is een jaar dat het op die locatie afsmelt. Die 150 jaar is inderdaad een gemiddelde, maar wel een over 10.000 jaar genomen. Hallo! Kijk je naar de laatste 2 keer dat er zo'n jaar was dan weten we dat 1889 de laatste keer was voor 2012, maar kijken we verder terug dan moet je ruim 800 jaar het verleden in. Dan ben je inmiddels aanbeland in de MWP. De media maakt er inmiddels een soort 150 jaars-cyclus van, ondanks dat Koenig zegt, 'on average'. Ik vrees dat ze dat niet had moeten zeggen, want uit de GISP2 ijskern blijkt gewoon heel duidelijk dat er helemaal niks om de 150 jaar gebeurt. Afbeelding
Bericht door Gerard » 26-07-2012 19:42
Interessante inbreng uit het hoge noorden! De gebeurtenis is dus (nog) uitzonderlijker dan in eerste instantie gedacht.
Het plaatje daaronder intrigeert me ook: dat suggereert dat er een langzaam proces bezig is geweest dat ervoor zorgt dat er geen (sneeuw) isolatie meer op het ijs van Groenland (bij de Summit?) aanwezig is op het Groenlandse ijs???
Als dat zo is dan is het te verwachten dat er meer van deze gebeurtenissen zullen gaan plaatsvinden.
WMP: Middle Eves Warm Period, de periode zo rond 1000 jaar AD.
Bericht door Oud-forumlid » 26-07-2012 19:51
Inderdaad Gerard Kos, er is iets aan de hand daar (op Summit, waar de GISP2 kern van de afbeelding ook vandaan komt.) en ik ben nog niet zoveel discussies of berichten tegengekomen waar men naast het Groenlandse weer van deze zomer ook nog de vinger wijst naar de albedo van de ijskap, maar die 2 samen moeten de smelt van dit jaar op hun geweten hebben en dat zegt niet veel goeds over de toekomst.
Bericht door Karel » 26-07-2012 20:01
majava schreef:
schreef:berichten tegengekomen waar men naast het Groenlandse weer van deze zomer ook nog de vinger wijst naar de albedo van de ijskap
Inderdaad speelt de sinds 2007 negatieve NAO in de zomermaanden gecombineerd met de verandering van de albedo van het Groenlands plateau een grote rol. In bijgaande publicatie van Dr.Box werd hierop al voor de 'juli 2012 gebeurtenis' gewezen.
http://bprc.osu.edu/~jbox/temp/Box et al. 2012 - TCD - resubmitted after review round 2.pdf
Dr.Box houdt ook een blog bij.http://www.meltfactor.org/blog/
Bericht door Gerard » 26-07-2012 20:08
V.w.b. de albedo: werd ook al aangetipt in het volgende Weereldnieuws-item.
https://www.vwkweb.nl/cms/index.php?opti ... &Itemid=27
