Mooi , maar hoe leg je koppeling positieve IOD - positieve NAO uit? Heb je daar studies over gevonden?Sebastiaan schreef: ↑05-09-2020 10:19Paul, ik schrijf trouwens een verhaal voor de Weerspiegel over de IOD van afgelopen winter.
Maandje oud.
https://rmets.onlinelibrary.wiley.com/d ... 2/asl.1005
Northern Europe and the UK experienced an exceptionally warm and wet winter in 2019/20, driven by an anomalously positive North Atlantic Oscillation (NAO). This positive NAO was well forecast by several seasonal forecast systems, suggesting that this winter the NAO was highly predictable at seasonal lead times. A very strong positive Indian Ocean dipole (IOD) event was also observed at the start of winter. Here we use composite analysis and model experiments, to show that the IOD was a key driver of the observed positive NAO. Using model experiments that perturb the Indian Ocean initial conditions, two teleconnection pathways of the IOD to the north Atlantic emerge: a tropospheric teleconnection pathway via a Rossby wave train travelling from the Indian Ocean over the Pacific and Atlantic, and a stratospheric teleconnection pathway via the Aleutian region and the stratospheric polar vortex. These pathways are similar to those for the El Niño Southern Oscillation link to the north Atlantic which are already well documented. The anomalies in the north Atlantic jet stream location and strength, and the associated precipitation anomalies over the UK and northern Europe, as simulated by the model IOD experiments, show remarkable agreement with those forecast and observed.
Boeiend artikel. Pagina 5-6 gaat over de twee pathways. Via de troposfeer en stratosfeer. Ik zou het fijn vinden als je het leest, sommige termen vragen om een goede vertaling
Stuur maar door . Interessant artikel, dank!Sebastiaan schreef: ↑06-09-2020 13:00Maandje oud.
https://twitter.com/MattHugo81/status/1 ... 7743508486
Latest EC Seasonal output is interesting, evidence for greater amplification to the N Atlantic pattern early on, through Nov and Dec, with then a more typical +NAO (wet n windy style) pattern as winter progresses. It doesn't show a raging +NAO/washout pattern like last winter...
I will correct myself, the studies show -NAO or Atlantic ridge (AR), perhaps Scandiblock (SC) with inactive MJO and mostly AR & SC when MJO is active over ph 3-6 in RMM framework during La Niña. Perhaps we see the result of LF forcing in the model.
Het patroon wordt duidelijk. Noordelijke hogedrukgebieden in november en december. Daarna zacht. Extreemste variant is december 2010.
Ja Sebastiaan, op het eerste gezicht een typische La Niña winter. Gelukkig veel spreiding rond het gemiddelde volgens de ECMWF ensembles de komende 6 maanden.
September update to ECMWF's SEAS5 predicting an increased likelihood of a negative NAO during November & December, with a subsequent transition to a positive NAO in February and March. For northwest Europe, this would suggest a greater risk of a "front-loaded" winter.
https://twitter.com/SimonLeeWx/status/1 ... 9025681409
Dit zegt Simon Lee erover. Engels meteoroloog. Bezig met promotie-onderzoek.
Inderdaad over november, december.januari is de NAO negatief in het gemiddelde van de berekening voor de september ensembleleden van het ECMWF model. Er zijn verder ensembleleden die een vorstperiode opleveren in december en januari. Februari en maart warmen op met positieve NAO. Hoeveel warmer hangt af van de temperatuur van het Noordzeewater.Sebastiaan schreef: ↑08-09-2020 17:56Voor wie zelf wil gluren https://effis.jrc.ec.europa.eu/applicat ... -forecast/
Afwachten wat de volgende berekening begin oktober oplevert.
Ook UKMO november/december/januari gemiddelde en kansberekening eind deze week afwachten.
