https://iopscience.iop.org/article/10.1 ... 326/ab0385
Abstract
The North Atlantic Oscillation (NAO), the regional manifestation of the Arctic Oscillation (AO), dominates winter climate variability in Europe and North America. Skilful seasonal forecasting of the winter NAO/AO has been demonstrated recently by dynamical prediction systems. However, the role of initial conditions in this predictability remains unknown. Using a latest generation seasonal forecasting system and reanalysis data, we show that the initial upper stratospheric zonal wind anomaly contributes to winter NAO/AO predictability through downward propagation of initial conditions. An initial polar westerly/easterly anomaly in the upper stratosphere propagates down to the troposphere in early winter, favoring a poleward/equatorward shift of the tropospheric mid-latitude jet. This tropospheric anomaly persists well into the late winter and induces the positive/negative phase of NAO/AO in the troposphere. Our results imply that good representation of stratospheric initial condition and stratosphere-troposphere coupling in models is important for winter climate prediction.
Abstract
The Canadian CanSIPS models continue to trend towards a stronger La Niña in early winter, with the latest SST forecast almost reaching -1.5°C in Niño3.4. With the PDO now strongly negative, a stronger La Niña is looking more credible. https://twitter.com/WorldClimateSvc/sta ... 7978204163
Met westelijke QBO op 1-5 hPa (zie mijn eerdere bijdrage over initial stratosphere), een hoog bij de Aleoeten en La Nina lijken mij de kansen vooral te liggen in het eerste deel van de winter. We wachten af
Sebastiaan bedankt voor de info.
Inderdaad afwachten de komende maanden. Niet te vergeten: de MJO ontwikkeling in de wintermaanden wordt van groot belang. Wanneer is er voldoende convectie in de Central Pacific?https://rmets.onlinelibrary.wiley.com/d ... 02/qj.3341
Ja, het artikel van Lee beschrijft ook duidelijk dat in een La Nina setting de pathway van MJO -> negatieve NAO actief is en die van MJO naar postieve MJO niet. Bij El Nino is dat andersom.
https://www.climate.gov/news-features/b ... do-we-care
Nu is het ook zo dat we een La Nina krijgen. Dat onderdrukt de neerslag (immers koeler zeewater). De vraag is dus in hoeverre fase 7 en 8 bereikt worden en met voldoende amplitude.
Het is dus te hopen dat we geen moderate of strong La Nina krijgen. Die verpesten extra neerslag en ruïneren transport van hitte van de tropen naar de Noordpool. Waardoor in de winter de strato. poolwervel op volle toeren kan draaien.
In dat opzicht is het jammer dat de QBO niet oostelijk lijkt te zijn (?)
https://www.researchgate.net/publicatio ... ion_models
Recent studies have shown that the Madden-Julian Oscillation (MJO) is significantly modulated by the stratospheric Quasi-Biennial Oscillation (QBO). In general, boreal winter MJO becomes more active during the easterly phase of the QBO (EQBO) than during the westerly phase (WQBO). Based on this finding, here we examine the possible impacts of the QBO on MJO prediction skill in the operational models that participated in the WCRP/WWRP subseasonal-to-seasonal (S2S) prediction project. All models show a higher MJO prediction skill during EQBO winters than during WQBO winters. For the bivariate anomaly correlation coefficient of 0.5, the MJO prediction skill during EQBO winters is enhanced by up to 10 days. This enhancement is insensitive to the initial MJO amplitude, indicating that the improved MJO prediction skill is not simply the result of a stronger MJO. Instead, a longer persistence of the MJO during EQBO winters likely induces a higher prediction skill by having a higher prediction limit.
Laatst gewijzigd door Sebastiaan op 03-09-2020 11:23, 4 keer totaal gewijzigd.
Het plaatje.
Nu de zomer voorbij is en de meteorologische herfst is begonnen, werken we langzaam naar het moment toe waarop we onze eerste versie van de verwachting voor de komende winter gaan uitgeven. Dat zal ergens in de tweede helft van september zijn.
Iedereen die onze verwachtingen voor de ultralange termijn met enige regelmaat volgt, weet dat er allerlei factoren zijn die we in de gaten moeten houden om tot een seizoensverwachting te kunnen komen. Ze hebben elk op hun eigen manier invloed op het weer bij ons en hun onderlinge samenhang bepaalt, waar het met het weer uiteindelijk naartoe zou kunnen gaan, in het seizoen dat in de verwachting centraal staat.
Van de vier seizoenen, is de winter qua drukverdeling en de factoren die daarop van invloed (kunnen) zijn het meest overzichtelijk. Dit heeft onder meer met de laagstaande zon te maken, die minder lokale effecten veroorzaakt dan bij voorbeeld in de zomer het geval is. Het gevoel onder meteorologen is dan ook dat we, als we er al eens in zouden slagen om betrouwbare seizoensverwachtingen te gaan maken, er voor de winter het dichtste bij zijn. En ook bij die verwachting gaat het gewoon nog heel vaak niet (helemaal) goed.
Nu kijken we naar wat er in de atmosfeer gebeurt
In aanloop naar de eerste versie van onze winterverwachting zullen we een aantal van de factoren, waarvan we nu eigenlijk al weten dat ze in de wintermaanden een rol gaan spelen, alvast tegen het licht houden. We keken al naar de invloed van de zon, de start van de nieuwe zonnevlekkencyclus, de zeeën en de rol van ijs en sneeuw, vandaag staat de invloed van de atmosfeer centraal; de plek waar het weer zich afspeelt.
In de vorige delen van deze korte serie zagen we al hoe de zon, de zeeën en ijs en sneeuw elk op hun eigen manier warmte in de luchtlaag om de aarde brengen, of daar (vooral in het geval van het ijs en de sneeuw) juist weer aan onttrekken. De manier waarop de aardse atmosfeer, die eigenlijk altijd in beweging is, hierop reageert, bepaalt hoe het weer er in een gebied uitziet. En dat is overal en altijd anders.
In een hogedrukgebied bijvoorbeeld daalt de lucht. Dalende lucht warmt op en droogt uit. In hogedrukgebieden is het vaak dan ook droog en zonnig weer. Dat geldt natuurlijk vooral voor de zones op aarde waar die hogedrukgebieden dominant zijn. In het verhaal over de invloed van de zon hebben we ze al benoemd: je moet dan vooral denken aan de woestijngordels die de aarde rijk is, bij ons in de buurt bijvoorbeeld de Sahara.
Als de lucht stijgt, koelt hij af en wordt vochtiger. Er ontstaat bewolking en als die dik genoeg is, valt er regen uit. Denk aan de ITCZ, die we ook in het verhaal over de invloed van de zon besproken hebben: de zone met zware regen- en onweersbuien die de zon min of meer volgt op zijn tocht door de tropen. Dit is bij uitstek een plaats waar de lucht stijgt en dus – iedere dag weer – zware regen- en onweersbuien ontstaan.
Bij ons regeren de lagedrukgebieden
De gematigde zones, waar ook Nederland bij hoort, zijn de gebieden waar de lagedrukgebieden actief zijn, zagen we in het verhaal over de invloed van de zon. Feitelijk worden ze daarbij afgewisseld door hogedrukgebieden. Het bijzondere aan de gematigde zones is dat zowel de hoge- als de lagedrukgebieden bewegen. Dit komt doordat het hier hoog in de atmosfeer hard waait. De Hadleycellen, die we eerder al hebben benoemd, worden hoog in de atmosfeer door verschillende straalstromen van elkaar gescheiden; smalle zones met een erg sterke wind. Zo heb je de subtropische straalstroom, de in de winter erg sterke straalstroom boven de gematigde breedten waar ook wij mee te maken hebben en de arctische straalstroom.
Zo’n smalle band met hoge windsnelheden, hoog boven ons, ligt feitelijk op de plaats waar verschillende luchtsoorten bij elkaar komen. De overgang van de ene naar de andere gaat in de praktijk niet geleidelijk, maar meer met een sprong. Op de grens ontstaat dan zo’n smalle strook met harde wind. Voor het weer bij ons is de straalstroom op de grens tussen polaire lucht aan de noordkant en subtropische aan de zuidkant belangrijk. Vooral in de winter zijn de temperatuurverschillen aan weerszijden groot en kan hij behoorlijk sterk zijn.
In de gematigde breedten is de straalstroom de leverancier van lagedrukgebieden. Ze ontstaan steeds weer en trekken over het noordelijke en zuidelijke halfrond naar het oosten. Tussendoor is de luchtdruk hoger en gedraagt het weer zich als in een hogedrukgebied. Met de koude lucht bij ons aan de noordkant en de warmere aan de zuidkant, is de trekrichting van zo’n lagedrukgebied bepalend voor in welke luchtsoort wij terechtkomen. En dat kan het verschil betekenen tussen de normale, zachte en incidenteel koude winters die we hebben.
Het zijn de verschillen die het hem doen
De grote lijn is altijd wel bekend, maar het zijn hier de verschillen die het hem doen. Meestal worden de Nederlandse winters door een aanhoudende westcirculatie gedomineerd en maakt koude lucht alleen een kans als de wind tussendoor ook eens even een tijdje uit het noorden of oosten waait. Dit is een situatie die zich de laatste jaren steeds minder vaak lijkt voor te doen. Wat nog weleens gebeurt, is dat lagedrukgebieden een winter lang ineens een heel andere koers dan anders volgen, en bij voorbeeld langere tijd veel zuidelijker dan normaal uitkomen. In dat geval kan ook Nederland toch nog voor langere tijd in de koude lucht aan de noordkant ervan terechtkomen en beleven we ineens wel een (relatief) koude winter.
Om de lagedrukgebieden voor wat langere tijd naar het zuiden te kunnen duwen, zijn hogedrukgebieden nodig, óf boven het Poolgebied, óf boven Scandinavië. De eerste variant met hogedrukgebieden boven het Poolgebied hebben we de laatste jaren nog wel een aantal keren gezien, de tweede variant komt nauwelijks meer voor. Voor de winters bij ons is het dus meestal bepalend wat zich in het hoge noorden afspeelt en hoe onze straalstroom daar op reageert. Hoe zuidelijker die terechtkomt, hoe groter bij ons de kans op winterweer.
In een chaotisch systeem, waarin alles met elkaar samenhangt, is het natuurlijk heel lastig om ver van tevoren al te weten hoe de straalstroom zich in het winterseizoen zal gaan gedragen. Toch kennen we inmiddels een flink aantal factoren die hierbij zo hun invloed kunnen hebben en weten we ook steeds beter wat voor gevolgen je dan mag verwachten. We hebben het al over de invloed van de zeeën gehad. In de voorbije winter leken bij voorbeeld vooral de watertemperaturen van de Indische Oceaan en die langs de evenaar op de Grote Oceaan tussen Peru aan de ene kant en Australië en Indonesië aan de andere kant een grote invloed op het weer bij ons te hebben. Ze wakkerden de straalstroom alleen maar aan en de westcirculatie wist van geen wijken meer. Het gevolg was dat de winter op een groot deel van het Noordelijke Halfrond uitzonderlijk zacht verliep.
Vergeleken met die voorgaande winter, is de situatie zowel op de Indische Oceaan als op de Grote Oceaan 180 graden gekeerd. Zouden deze twee gebieden ook de komende winter dominant zijn, dan kon er weleens een heel ander beeld uit de bus komen. Meestal is het echter niet zo eenvoudig. Iedere winter kent zijn eigen, dominante factoren en die kunnen jaarlijks flink van elkaar afwijken. Zo wordt de komende winter ook invloed van het op gang komen van de nieuwe zonnevlekkencyclus verwacht, we hebben het daar in het verhaal over de invloed van de zon al even over gehad. Verder is een straalstroom boven de evenaar, die periodiek van oost naar west en dan weer terug naar oost draait, van belang en wordt rekening gehouden met de temperaturen op de noordelijke helften van de Grote Oceaan en van onze Atlantische Oceaan. De resultante van dit krachtenspel zal een voorkeurspositie voor de straalstroom in de komende winter opleveren. En daar hangt alles vanaf.
Zelf volgen
Voor mensen die het willen volgen, zijn er twee interessante indices die iedere dag worden bijgewerkt en in de toekomst worden doorgerekend. Het gaat om de NAO-index, die iets zegt over het drukverschil tussen IJsland en de Azoren, en de AO-index, die iets vertelt over de drukverdeling in het Noordpoolgebied. Onder normale omstandigheden zal de luchtdruk bij IJsland lager zijn dan boven de Azoren. Op ons deel van het Noordelijke Halfrond is in dat geval sprake van een westcirculatie en de NAO-index is positief. Volgen de lagedrukgebieden om wat voor reden dan ook eens een tijdje een wat zuidelijkere koers, dan daalt de luchtdruk bij de Azoren en stijgt de luchtdruk bij IJsland. De NAO-index kan dan negatief worden. De grootste kansen op winterweer zijn er in Nederland bij een negatieve NAO-index, maar een garantie biedt die niet.
De AO-index vertelt iets over de drukverdeling in het Poolgebied. Is de luchtdruk er gemiddeld gesproken laag, dan is de AO-index positief. De kans op koud winterweer bij ons is dan niet zo groot omdat de lagedrukgebieden de koude lucht goed binnen de poolcirkel weten te houden. Dat was de situatie gedurende de afgelopen winter. Gaat de luchtdruk in het poolgebied om wat voor reden dan ook omhoog, dan zal de AO-index negatief worden. En neemt de kans op uitbraken van kou naar het zuiden toe. Ook dan biedt dit geen garantie, want de vraag is vervolgens wel waar die koude lucht dan uiteindelijk precies terecht komt. Wel is het leuk om beide indices gedurende de winter te volgen. Je krijgt dan veel meer een gevoel voor wat er aan de hand is.
Zelf volgen
QBO 4,78 in augustus. Westelijk dus. Wordt denkelijk oostelijk in de winter.
Over glosea5: even terugkoppeling.
Helemaal niet slecht, deze zomer. Belangrijk figuur uit eerdere studie dit topic: https://agupubs.onlinelibrary.wiley.com ... 19GL084683
Interessant lezen hier, Karel en Sebastiaan ...
Ik denk dat je dit bedoelt:Sebastiaan schreef: ↑03-09-2020 10:39Ja, het artikel van Lee beschrijft ook duidelijk dat in een La Nina setting de pathway van MJO -> negatieve NAO actief is en die van MJO naar postieve MJO niet. Bij El Nino is dat andersom.
Ja, het artikel van Lee beschrijft ook duidelijk dat in een La Nina setting de pathway van MJO -> negatieve NAO actief is en die van MJO naar positieve NAO niet. Bij El Nino is dat andersom.
Fase 7 en 8 MJO zijn inderdaad moeilijk bij sterke La Nina. Ik maak op uit NOAA rapportage dat het wel mee zal vallen met de kracht van de La Nina. Zelfs neutraal is nog goed mogelijk. https://www.cpc.ncep.noaa.gov/products/ ... ts-web.pdf Alleen: Glosea5 is het daar niet mee eens, gezien de respons in PDO-bereik.
Over de QBO: oostelijke fase zit dichtbij. Zowel hoger als lager in de stratosfeer is de wind oostelijk, boven de evenaar.
Sorry ja. Positieve MJO bestaat niet
Paul, ik schrijf trouwens een verhaal voor de Weerspiegel over de IOD van afgelopen winter.
Laatst gewijzigd door Sebastiaan op 05-09-2020 10:37, 1 keer totaal gewijzigd.
