warmte en nog eens warmte in het buitenland
Bericht door Gert » 07-06-2017 16:46
Beste mensen,
De laatste tijd is het in delen van Europa en Azië zeer warm geweest. Weatherunderground heeft hier aandacht aan besteed. Zie onder
Historic Heat Wave Sweeps Asia, the Middle East and Europe
Dr. Jeff Masters  ·  June 6, 2017, 4:04 PM
Above:  People cool themselves off in a water channel during a heat wave on June 4, 2017 in Lahore, Pakistan. Image credit: ARIF ALI/AFP/Getty Images.
The last week of May 2017 and first week of June brought one the most extraordinary heatwaves in world history to Asia, the Middle East and Europe. The mercury shot up to an astonishing 53.5°C (128.3°F) at Turbat, Pakistan on May 28, making it Earth’s hottest temperature ever recorded in the month of May—and one of Earth’s top-five hottest reliably-measured temperatures on record, for any month. Both Pakistan and Oman tied their all-time national heat records for any month during the heat wave, and all-time national heat records for the month of May were set in Iran, Norway and Austria. International weather records expert Maximiliano Herrera details the great heat wave in this guest post.
Middle East and Southwest Asia heat wave
During the last week of May, an impressive dome of overheated air with an isotherm of 35°C (95°F) at 850 hpa (approximately 5,000 feet) extended across the Strait of Hormuz near southern Iran and southwestern Pakistan. In places where this air was being forced downward, the extreme heat allowed for strong compressional warming that produced exceptional surface temperatures. On May 28, after a minimum temperature of 34.5°C (94°F), the high temperature in the Western Pakistani town of Turbat reached 53.5°C (128.3°F) in mid-afternoon. This tied the all-time highest temperature ever recorded in Pakistan, and the world record of highest temperature for May--both set in Moen Jo Daro on May 26, 2010 (not May 27 as wrongly reported in some media.)
There is a controversy about the correct maximum temperature in Turbat, though. It was reported by the Pakistan Meteorological Department as 53.5°C (the precision of the thermometer is 0.5°C, like in most Pakistani stations), but the temperature was later rounded to 54.0°C (129.2°F.) If that is correct, it would tie the highest reliable temperature ever recorded in the planet, the 54.0°C reading set on July 21, 2016 in Mitribah, Kuwait. Regardless, the 53.5°C reading at Turbat on May 28, 2017, ranks as one of Earth’s top five hottest reliably-measured temperatures on record; see Wunderground weather historian Chris Burt’s July 22, 2016 post, Hottest Reliably Measured Air Temperatures on Earth, for more information. The World Meteorological Organization, which is currently checking the reliability of the Mitribah thermometer, will also carry out an investigation on the reliability of the Turbat reading--and to find out whether this rounding from 53.5°C to 54.0°C makes sense.
In nearby eastern Iran, the temperatures peaked at 52.8°C (127°F) at the military base of Konarak, and 52.6°C (126.7°F ) in the village of Renk, destroying the record of the highest temperature ever recorded in May in Iran (50.5°C in Bostan in May 1999), and approaching the highest reliable temperature ever recorded in Iran, 53°C.
In the following days, the intense heat moved down to Oman, where nearly half of the stations set their all-time highest temperatures. The most important of these records were the 50.8°C (123.4°F) recorded on May 30 at Qurayyat and on May 31 at Joba. These readings tie the national record of highest temperature ever recorded in Oman (previously set at Buraimi in July 1990 and at Sohar Majis in May 2009.)
In Saudi Arabia, after a wind shift, an exceptional value of 48°C (118.4°F) was recorded in the port of Wejh (Al Wahj), tying the highest temperature ever recorded in the Northwestern coast of Saudi Arabia (facing the Red Sea); the same value was recorded in June 1978.
In the United Arab Emirates, the difference of temperature between the atmosphere and the sea, together with the intense sea breeze, caused impressive differences in weather. Coastal areas were affected by thick fog, and even mist, but temperatures were very high on the mountain peaks. At one point, the temperature of the weather station on the Burj Al Khalifa Building in Dubai (625 meters above sea level) was 15°C (27°F) higher than that of coastal Dubai.
Figure 1. Screen shot of the Pakistan Meteorological Department's web page on May 28, 2017, showing that the all-time Pakistan heat record of 53.5°C (128.3°F) had been tied that day.
European heat wave
A dome of high pressure from Morocco extended over Western Europe beginning on May 24, then moved north and then east. As a result, monthly records of highest temperatures were widespread in Spain, France, Belgium, Netherlands, Ireland, Norway, Germany and Austria. Very high temperatures were also set in the Alps, with an amazing 5.8°C (42.4°F) on May 27 on the top of Italy’s Col Major (elevation 4750 meters or 15,584 feet), just at the side of Mount Blanc. In particular, two national records for the month of May were broken: in Norway with 32.2°C (90°F) at Tinnsjø on May 27, and in Austria with 35.0°C (95°F) at Horn on May 31.
Vietnamese heat wave
An intense heat wave caused by downslope winds from the Laotian mountains towards the Vietnamese coast affected the area around Vietnam’s capital of Hanoi in early June, particularly between June 2 - 4. The central observatory of Lang on June 3 recorded 41.5°C (106.7°F), destroying its previous all-time record of 40.4°C, set in 1971. On June 4, the district of Ha Dong (which hosts an international weather station representative of Hanoi) recorded 42.5°C (108.5°F), by far the highest temperature ever recorded in the Hanoi area. (During the colonial times, unusually high values were recorded with stations affected by overexposure conditions, including the infamous record of 42.8°C in May 1926, which is believed to be unreliable--just like similar values recorded in Indochina in those years.) In the central area of Hanoi, near Hoan Kiem Lake, the humidity is usually higher than its surroundings, and the combination of temperatures as high as 41°C (105.8°F) with humidity values near 50% made the heat index an unbearable 55°C (131°F).
Jeff Masters contributed to this post.
Laatst gewijzigd door Gert op 07-06-2017 22:02, 1 keer totaal gewijzigd.
Re: warmte en nog eens warmte in het buitenland
Bericht door Daniël » 08-06-2017 19:56
Zijn er ergens op de oceanen op het Noordelijk Halfrond grote afwijkingen van oceaanwatertemperaturen die deze hittegolven veroorzaken?
Bericht door Karel » 14-07-2017 20:33
De afwijkingen op de oceanen zijn gering ten opzichte van de afwijkingen op land.
Overigens is de gemiddelde temperatuur over de eerste 13 dagen van juli 2017 mondiaal gezien ongeveer normaal. De gemiddelde afwijkingen op land zijn afhankelijk van het circulatiepatroon naar boven en naar beneden zeer groot. Gisteren bijvoorbeeld was de maximum temperatuur op het vliegveld van Cordoba 47 C.
Bronnen:
http://www.ogimet.com/cgi-bin/gsynres?lang=en&state=Spa&osum=no&fmt=html&ord=REV&ano=2017&mes=07&day=13&hora=18&ndays=1&Send=send
https://twitter.com/MJVentrice
Bericht door Edward » 15-07-2017 00:04
Karel schreef: Gisteren bijvoorbeeld was de maximum temperatuur op het vliegveld van Cordoba 47 C.
Vandaag ook weer bijna 46 graden daarzo (extremen vandaag en gisteren van het metoffice van Spanje).
Laatst gewijzigd door Edward op 15-07-2017 00:06, 1 keer totaal gewijzigd.
Bericht door Gert » 08-08-2017 10:22
De VS en het zuiden van Europa hadden of hebben nog steeds te maken met hitte.Jan Visser heeft er de nodige aandacht aan besteed. Zie onder. Indrukwekkend allemaal
Verzengende hitte in een groot deel van zuidelijk Europa deze zomer; zinderende hitte ook in het westen van de Verenigde Staten. In de hoofdstad van de Amerikaanse staat California werd gisteren de 41ste opeenvolgende dag met een maximumtemperatuur van tenminste 32,2º Celsius (90º Fahrenheit) geregistreerd. Dat betekende een record in de meer dan 120 jaar lange meetreeks. Het record stond op 40 dagen in 1992. Toen werd het van 13 juli t/m 21 augustus tenminste 32,2º Celsius. Vorige week was het ook zeldzaam heet in het noordwesten van de VS ofwel de Pacific Northwest. In diverse steden in de staten Washington en Oregon werden datumrecords gevestigd. Op 1 en 2 augustus zinderende Medford in Oregon naar respectievelijk 43,3 en 44,4º
Bericht door Gerben » 08-08-2017 21:45
Alaska en noordwest Canada krijgen te maken met zeer vroege sneeuwval komend weekend.
Laatst gewijzigd door Gerben op 08-08-2017 21:45, 1 keer totaal gewijzigd.
Bericht door Daniël » 10-08-2017 19:24
