Typhoon season Western Pacific 2016
Re: Typhoon season Western Pacific 2016
Laatste stand van de tropische storm "MERANTI": 160 knopen, 896 mbar.
De prognose voor de ZO kust van China ziet er nu wat dreigender uit. Ook zit Hong-Kong nu niet meer helemaal "uit de vuurlinie".
Mazzel, Evert
Mazzel, Evert
Hieronder de top noteringen van tropische orkanen wat betreft luchtdruk
Meranti is even more impressive than Winston in another way. Because Meranti is so large, its central pressure is even lower than would be the case for a smaller storm that had the same peak winds. At 1250Z (8:50 am EDT) Tuesday, the Japan Meteorological Agency analyzed Meranti’s central pressure at 890 millibars. This puts Meranti in the elite pantheon of the deepest tropical cyclones ever recorded anywhere on Earth. Several others have had 890 mb central pressure, but only a few have dipped below that mark, including 2 hurricanes in the Atlantic, 1 hurricane in the Northeast Pacific, and 13 typhoons in the Northwest Pacific:
Typhoon Tip (1979) - 870 mb
Hurricane Patricia (2015) - 872 mb
Typhoon June (1975) - 875 mb
Typhoon Nora (1973) - 875 mb
Typhoon Ida (1958) - 877 mb
Typhoon Kit (1966) - 880 mb
Typhoon Rita (1978) - 880 mb
Typhoon Vanessa (1984) - 880 mb
Typhoon Nancy (1961) - 882 mb
Hurricane Wilma (2005) - 882 mb
Typhoon Forrest (1983) - 885 mb
Typhoon Irma (1971) - 885 mb
Typhoon Megi (2010) - 885 mb
Typhoon Nina (1953) - 885 mb
Typhoon Marge (1951) - 886 mb
Hurricane Gilbert (1988) - 888 mb
Ter informatie
Volgens de Monterey site van de Amerikaanse marine (http://www.nrlmry.navy.mil/TC.html) was het hoogtepunt van de storm als volgt:
165 knopen (±305 km/h), 887 mbar
Mazzel & broge, Evert
Indrukwekkend in de Pacific. Op de Atlantische Oceaan spettert de activiteit bij Julia en Karl er veel minder van af.
Overigens is 18W Malakas ( 110 kts, 945 hPa, 24,1N, 123,0E ) wat vertraagd en trekt vandaag125km oostelijk van Taipeh richting Sasebo (Japan), Aankomst daar als typhoon force 1 met een flinke plens regen op 20 september.
Opnieuw een nieuwe actieve typhoon in de Pacific. Typhoon 20W MEGI (18,6N, 133,9E, 65 kts,981 hPa) intensifeert tot cat 3 (105kts) volgens de modellen. Op 27 september wordt MEGI op Taiwan gepositioneerd.
Op de Atlantische Oceaan nog steeds weinig activiteit in Karl en Lisa. Het aantal TD'S is hier wel boven gemiddeld, maar de ACE blijft onder gemiddeld.
De volgende actieve typhoon in de Pacific is 21W Chaba (17,7N, 133,7E, 65 kts, 974 hPa).
Modelberekeningen geven Chaba een koers richting Sasebo Japan. De activiteit van Chaba zal verder toenemen tot typhoon cat 3- 105 kts volgens de berekeningen (geringe windschering in de bovenlucht richting Japan). Als de baan inderdaad van zuid naar noord geheel over Japan voert dan kunnen daar grote neerslaghoeveelheden worden verwacht.
Chaba, inmiddels 940 hPa als cat 3 morgen tussen Zuid-Korea en Japan doortrekkend richting het noorden van Japan.
Iets om een oogje op te houden:
"Sarika" gaat op Vietnam af. Hoe krachtig de storm zal zijn bij het aanlanden hangt af van de eventuele interactie met het zuid Chinese eiland Hainan. Als hij er onderdoor duikt kan het in Vietnam flink los gaan.
"Haima" gaat op Hongkong af en haalt mogelijk cat. 5 bij Philipijnen. Als ik in Hongkong zou wonen zou ik deze storm nauwlettend volgen. Ook hier: Als de storm door de Luzon Straat duikt met weinig interactie met Luzon moet Hongkong bij aanlanden met een cat. 4 rekening houden.
Maar het kan natuurlijk ook (weer eens) met een sisser aflopen.
Haima heeft inderdaad cat 5 gehaald maar koerst naar China ruim oostelijk van Hong Kong.
Sarika gaat als cat 1 typhoon pal over Hainan en trekt afnemend in activiteit ook verder naar China.
Haima heeft vandaag wel Luzon ten noorden van Manila flink getroffen. Veel regen in het bergachtig gebied daar bijvoorbeeld: de rijstterrassen bij Banaue. De koers en intensiteit richting Hongkong moet na de stevige interactie met land worden afgewacht.
