El Nino topic
Re: El Nino topic
Bericht door Sebastiaan » 19-05-2023 13:41
Adwin schreef:
19-05-2023 12:22
Hoe bedoel je dat "uiteraard" ten gevolge van de neerslag? Heel Europa is toch nat behalve Spanje?
Hai Adwin, ik heb het over Italië. Je ziet in de omgeving daarvan, koeler water dan gebruikelijk. Ik koppel dat aan de neerslag die daar momenteel valt ;)
Re: El Nino topic
Bericht door Sebastiaan » 22-05-2023 09:47
Compared to late winter, the early winter response of the NAE region to ENSO is only starting to be understood (Abid et al., 2021; Ayarzaguena et al., 2018; King et al., 2018). The next section analyses the relationship between the EAP and wider climate drivers in early winter, to assess the physical processes involved.
In early winter observations, a positive EAP is associated with warmer Pacific equatorial SSTs (El Niño, Figure 3a), increased rainfall over the tropical Pacific and western Indian Ocean (Figure 3b) and a weakened Walker circulation (Figure 3c). Such dynamics are known to generate Rossby waves which then propagate into the mid-latitudes (Abid et al., 2021; Ayarzaguena et al., 2018; Hoskins & Karoly, 1981; Scaife, Comer, Dunstone, Knight, et al., 2017). Two Rossby wave trains appear to be associated with the EAP, one originating in the tropical west Pacific and arching around the Pacific basin, the other originating in the Caribbean/Gulf of Mexico region, propagating north and east into the Atlantic basin (Figure 3d). The Rossby wave trajectories seen here agree with those observed in early winter El Niño events (Ayarzaguena et al., 2018, see their Figure 5 for example trajectories). The net effect of these Rossby wave trains is a low-pressure center to the west of the UK that projects onto the EAP.
https://agupubs.onlinelibrary.wiley.com ... 22GL100712
Re: El Nino topic
Bericht door Sebastiaan » 09-06-2023 16:24
El Niño is nu echt begonnen
Het is zover. Experts van de Amerikaanse weerdienst hebben verklaard dat El Niño, de warme zeestroom op de Grote Oceaan langs de evenaar tussen Peru en Indonesië, nu echt is begonnen. Nu alle drempelwaarden zijn overschreden, wordt aan de voorwaarden voor de start van een El Niño voldaan. Het fenomeen zal het weer op veel plekken op aarde de komende tijd flink op zijn kop zetten, zo wordt verwacht. Of doet dat nu al.
Zo lijkt het warme en droge weer van de laatste tijd in Canada met de daarbij behorende wilde start van het natuurbrandseizoen daar direct met het begin van El Niño samen te hangen. Het noordoosten van de VS, inclusief steden als New York, Philadelphia en Washington DC, zat deze week een tijdlang onder dikke rookwolken, afkomstig van de vele branden die in de Canadese provincie Quebec woeden. Ook de uiterst natte winter in het zuidwesten van de VS kan aan de start van El Niño worden toegeschreven.
Australië en Indonesië
Andere plekken op aarde die mogelijk op weersextremen kunnen rekenen, zijn Australië (in plaats van nat de afgelopen jaren weer droog en warm), Indonesië (droger dan normaal), het Amazonegebied (droger dan normaal) en sommige westelijke delen van Zuid-Amerika (natter dan normaal). Mogelijk krijgt de Hoorn van Afrika eindelijk ook weer regen.
In Europa zijn de gevolgen van El Niño minder duidelijk. Wel zien we ook hier veranderingen, al is dus niet meteen gezegd dat die ook door de start van El Niño komen. Lagen de hogedrukgebieden bij ons de afgelopen jaren steeds boven het zuiden, met in de landen rond de Middellandse Zee in de zomermaanden grote droogte en vaak ook extreme temperaturen tot gevolg, nu liggen ze noordelijker. In het zuiden van Europa is het daardoor de laatste tijd juist wisselvalliger geworden en bij ons alweer langere tijd droog.
Wereldwijd temperatuurrecord
El Niño maakt ook dat de kans groeit dat het warmterecord voor de gemiddelde temperatuur op aarde volgend jaar voor het eerst sinds 2016 scherper wordt gesteld. Ook komt de stijging met anderhalve graad van de aardtemperatuur, die in de afspraken rond het klimaatakkoord van Parijs zo’n grote rol speelt, voor het eerst (tijdelijk) in zicht.
El Niño is een warme zeestroom langs de evenaar, tussen Zuid-Amerika aan de ene en Indonesië aan de andere kant. De zeestroom ontstaat als bij de kust van Zuid-Amerika warm zeewater uit de diepzee opwelt en van daar door oostenwinden naar het westen wordt gedreven. Dat warme water is er op eerder momenten in de diepzee al vanuit het westen aangevoerd. Zo’n El Niño (dit wordt een sterke) komt eens per 2 tot 7 jaar voor.
Grote invloed op het wereldwijde weer
Er zijn weinig fenomenen die zo’n grote invloed op het weer hebben als El Niño en La Niña. Tijdens de La Niña van de afgelopen drie jaar viel in grote delen van Zuid-Amerika (veel) minder regen dan normaal, door het aanwezige koude zeewater daar. Het noordoosten van het werelddeel (waar Suriname ligt) was juist natter. Natter was het verder in Indonesië en in het oosten van Australië, de gebieden waar het warme zeewater zich ophoopte.
Beide kanten van de Oceaan waren de afgelopen jaren vaak in het nieuws. Er werd bericht over de grote droogte in delen van Zuid-Amerika, maar ook over het natte weer in het noordoosten. De regen in het oosten van Australië maakte meer dan eens koppen. Na de extreme droogte met de verschrikkelijke bosbranden in de jaren ervoor, ging het de laatste 3 jaar vooral over overstromingen, extreme regenval en over het feit dat het water op alle plekken, waar het daarvoor was verdwenen, weer terugkeerde.
Zuidwesten VS
Groot was de invloed van La Niña ook in de Verenigde Staten. Het zuidwesten beleefde een dramatische droogte. De stuwmeren staan er nog laag, al lopen ze wel op. Tegelijkertijd kwam het er tijdens de zomers tot verschroeiende hittegolven. Verder naar het noorden was het wel natter en haalde de kou tijdens de winters af en toe fel uit. Een enkele van die koudegolven rolde door naar het zuiden en deed ook een staat als Texas aan.
Nog verder bij de bron vandaan waren de moessons en India en vooral in Pakistan natter dan normaal. Meerdere keren zagen we dramatische beelden van gebieden die onder een dikke laag water waren verdwenen en waar de inwoners huis en aard verloren. In de Hoorn van Afrika werden tezelfdertijd meerdere regentijden overgeslagen. In landen als Ethiopië heerst nu een dramatische droogte en is op veel plaatse van hongersnood sprake.
Nu El Niño is begonnen, krijgen de meeste van de hiervoor genoemde gebieden met in grote lijnen tegengestelde extremen te maken. Nat wordt droog en warm, terwijl het op de tijdens de La Niña droge en warme plaatsen juist natter en gematigder kan worden.
Europa
Europa ligt het verst bij het brongebied van El Niño en La Niña vandaan. Hier is het dan ook het lastigste om aan te geven wat de gevolgen van de twee fenomenen voor het weer bij ons zijn. Toch waren er de afgelopen jaren meteorologen die een samenhang vermoedden tussen het hardnekkig voorkomen van hogedrukgebieden boven het zuiden en midden van Europa en La Niña. Grote droogtes in delen van Frankrijk, het Alpengebied, Italië en vrijwel heel het Middellandse Zeegebied, tot en met Turkije en de omgeving van de Zwarte Zee aan toe, hingen ermee samen. Ook in Nederland kregen we er ons deel van mee. Op enkele uitzonderingen na, verliepen het voorjaar en de zomer steeds droog. Met ook bij ons terugkerende hittegolven en de bijbehorende schade voor de verdroogde natuur. Ook landbouw en veeteelt hadden veel last van het opstandige weer. Inmiddels is de situatie omgekeerd, maar zoals al aangegeven is het lastig om dit aan El Niño te wijten. https://www.weer.nl/nieuws/2023/el-nino ... t-begonnen
Re: El Nino topic
Bericht door Sebastiaan » 11-06-2023 09:36
Update.
Re: El Nino topic
Bericht door Daniël » 11-06-2023 17:23
Update.
Dit Twitterdraadje is te volgen op https://twitter.com/BenNollWeather/stat ... 0017200129.
Re: El Nino topic
Bericht door Sebastiaan » 17-06-2023 11:41
Re: El Nino topic
Bericht door Sebastiaan » 17-06-2023 14:07
El Nino rond 1,5c. Zeer fors dus, maar het kan extremer. Euro vnl opwarming aan de oostelijke kant.
Re: El Nino topic
Bericht door Sebastiaan » 20-06-2023 22:06
5. Conclusions
The present work investigated the different ENSO impacts on the NAO during early and late winter and the possible roles of various mechanisms. Our observational analyses support the finding of the subseasonal variation in the ENSO-NAO linkage and identify the crucial physical processes responsible for the phase shift in NAO during ENSO early and late winters. During El Niño early winter, the North Atlantic experiences a positive NAO-like pattern of atmospheric pressure due to the weakening of the tropical Walker circulation and the associated alteration in the meridional circulation over the North Atlantic. However, the North Atlantic is dominated by a negative NAO-like atmospheric response over the North Atlantic during El Niño late winter. The phase shift in the NAO response to ENSO is closely related to the ENSO-induced NTA SST anomalies in late winter. During El Niño late winter, there appears obvious SST warming over the NTA, which can excite the local convection and thus, generate a negative NAO response. Moreover, the full establishment of the PNA teleconnection in late winter could also make some contribution to the simultaneous negative ENSO-NAO relationship. The strongly enhanced positive PNA teleconnection could partially account for the negative NAO response during El Niño late winter, but its effect is confined to the western edge of the NAO. Similar mechanisms work during La Niña. The understanding of different mechanisms for the subseasonal variation in the ENSO-NAO relationship from early to late winter provides useful information for seasonal prediction over the North Atlantic–European region.
https://www.mdpi.com/2225-1154/11/2/47
