Winter 2022
Re: Winter 2022
De schrijver gaat uit van een mixed type.
In jouw lijst zie ik diverse varianten
Abstract
Recent modeling studies have shown an important role for stratosphere-troposphere coupling in the large-scale atmospheric response to Arctic sea ice loss. Evidence is growing that the Quasi-biennial Oscillation (QBO) can contribute to or even mitigate teleconnections from surface forcing. Here, the influence of QBO phase on the atmospheric response to projected Arctic sea ice loss is examined using an atmospheric general circulation model with a well-resolved stratosphere and a QBO prescribed from observations. The role of the QBO is determined by compositing seasons with easterly phase (QBO-E) separately from seasons with westerly phase (QBO-W). In response to the sea ice forcing in early winter, the polar vortex during QBO-E weakens with strong stratosphere-troposphere wave-1 coupling and a negative Northern Annular Mode-type response. At the surface, this results in more severe Siberian cold spells. For QBO-W, the polar vortex strengthens in response to the sea ice forcing.
Plain Language Summary
Rapid loss of Arctic sea ice area and thickness are key indicators of global climate change. Global climate models project further loss of Arctic sea ice through the end of the 21st century. How weather patterns and the jet stream will respond to this sudden loss of sea ice is still poorly understood. Here we use a series of climate model experiments to understand how the atmospheric response to sea ice loss is affected by alternating easterly and westerly winds in the tropical middle atmosphere, known as the Quasi-biennial Oscillation. We show that the Quasi-biennial Oscillation has an important role in understanding how weather patterns can respond to a decrease in sea ice. https://agupubs.onlinelibrary.wiley.com ... 19GL083095
https://twitter.com/SimonLeeWx/status/1 ... 0176502786
Abstract
Re: Winter 2022
Simon Lee is wakker geworden...
Re: Winter 2022
Het lijkt erop dat de noordelijke Pacific eindelijk eens wat gaat afkoelen. Wat heeft dat voor gevolgen voor onze winter als het zeewater daar kouder is dan normaal?
Re: Winter 2022
@ Gerben
"Het lijkt erop dat de noordelijke Pacific eindelijk eens wat gaat afkoelen. Wat heeft dat voor gevolgen voor onze winter als het zeewater daar kouder is dan normaal?"
Afkoeling in de herfst is normaal, maar wat is de invloed van de sst temperatuurverdeling op de atmosferische circulatie op het Noordelijk Halrond?
Invloed op circulatiepatronen van de 3 varianten (eof's) van de zeewatertemperatuurverdeling op de noordelijke pacific is hier te vinden
https://atmos.washington.edu/~dennis/Ha ... etters.pdf en https://agupubs.onlinelibrary.wiley.com ... upinfo.zip
"Pacific sea surface temperature
and the winter of 2014
Dennis L. Hartmann
Department of Atmospheric Sciences, University of Washington, Seattle, Washington, USA
Abstract:
It is shown from historical data and from modeling experiments that a proximate cause of the
cold winter in North America in 2013–2014 was the pattern of sea surface temperature (SST) in the Pacific
Ocean. Each of the three dominant modes of SST variability in the Pacific is connected to the tropics and has a
strong expression in extratropical SST and weather patterns. Beginning in the middle of 2013, the third mode
of SST variability was two standard deviations positive and has remained so through January 2015. This
pattern is associated with high pressure in the northeast Pacific and low pressure and low surface temperatures
over central North America. A large ensemble of model experiments with observed SSTs confirms that SST
anomalies contributed to the anomalous winter of 2014."
De huidige sst temperatuurverdeling op het Noordelijk Halfrond:https://psl.noaa.gov/map/clim/sst.shtml
Dennis L. Hartmann
Abstract:
Re: Winter 2022
De SST temperatuurverdeling op de Atlantische Oceaan is van belang voor de winter in Europa volgens recent onderzoek:The Atmospheric Response to North Atlantic SST Trends, 1870–2019
Kristopher B. Karnauskas
https://agupubs.onlinelibrary.wiley.com ... SI-S01.pdf
en https://www.dillonamaya.com/s/grl_karnauskas_21.pdf
Re: Winter 2022
Interessant, al die hier beschreven benaderingswijzen van hoe de aanstaande winter wel eens zou kunnen verlopen.
Naast dit, volg ik al enige maande dagelijks de CFS runs, om te bespeuren of hier een trend zichtbaar is.
En vanzelf binnen de dagelijkse runvariaties is er mi wel een lijn te ontdekken.
De maand oktober lijkt veel hogedruk ten zuiden en zuidwesten te geven, vrij droge en milde condities derhalve, met opvallend weinig polaire NW stromingen.
Deze lijken tegen het einde van oktober en mn in november geleidelijk meer en meer kansen te krijgen. Onderliggend lijkt hogedruk dan meer een positie ten westen te hebben waardoor periodiek in ieder geval koudere lucht er in kan komen.
Zo tegen 2e decade november zou eea wel eens tot een wat serieusere kou -voor korte tijd- kunnen leiden.
Na een wat zacht en wisselvallig 1e deel december zie je dat er juist rond Kerst grotere kansen op winterkou komen. Onderliggend zie je vanaf dan vaker dat westelijke H verbinding maakt met Scandi H, grotere kansen op continentale aanvoer.
Dat beeld zet zich in de maanden januari en februari voort. Denk zeker niet dat het aaneengesloten kou zal zijn, daarvan is volgens de trend geen sprake, grote -wekelijkse-afwisseling van winter kou met juist perioden met opvallend hoge bovenluchttemperaturen, hoewel dit in de winter nog niet hoeft te betekenen dat het aan de grond mild is, zeker gezien het onderliggende patroon van Europese hogedruk.
Een wat mij betreft heerlijk afwisselende winter staat er volgens CFS op het program vooralsnog. Met hierbij nog de opmerking dat ook opvallend is dat de kansen op kou zeker ook de in de maanden maart en april nog aanwezig is, lijkt lange winter te gaan worden, met dan opvallend dat vaak de grootste bovenluchtkou (op 1500 meter < -15 C) in maart zuidwaarts gaat afzakken. Zou dit onderliggend er op wijzen dat CFS met een SSW rekening houdt ergens 1e deel januari?
Re: Winter 2022
Ja, CFS komt met SSW
http://www.weatheriscool.com/prod/inter ... serie.html
Re: Winter 2022
Ja weet ik maar het lijkt erop dat de komende tijd in die regio eindelijk wat kouder is dan normaal...Karel schreef: ↑27-09-2021 08:57@ Gerben
Re: Winter 2022
Nu de modelberekeningen een sterke indicatie geven voor een SSW in jan/feb de komende winter heb ik de QBO/SolarFlux/ENSO grafiek van Labitzke erbij gehaald. De koude ENSO jaren met een QBOE ,een SolarFlux <100 en een SSW zijn 1963,1985, 2006 en 2008. Wanneer daarbij ook nog de huidige positieve AMO-fase ( Atlantic Multidecadal Oscillation Index according to the methodology proposed by van Oldenborgh et al. 1880-2018.)wordt gebruikt voor selectie blijft januari/februari 2006 (strenge winter in Berlijn maar veel frustratie bij ons) boven de streep over. Gewoon maar uitgaan van nieuwe winter met een nieuwe kans op een mogelijke SSW met een wave-1/2 dominantie. Natuurlijk is een koude periode eind november/december ,dat met flink afkoelen van de Noordzee gepaard gaat, een belangrijke aanzet voor de kans op winterweer in januari/februariSebastiaan schreef: ↑27-09-2021 16:00Ja, CFS komt met SSW
Re: Winter 2022
Op https://www.bloomberg.com/news/articles ... rices-soar "Europe’s Energy Crisis Is Coming for the Rest of the World, Too" lees ik dat een koude winter echt voor grote problemen kan zorgen als het om onze energievoorziening gaat, juist er nu al schaarste aan aardgas is, de gas- en stroomprijzen daardoor nu al zo hoog zijn en voor veel huishoudens de energierekening nu al onbetaalbaar dreigt te worden.
