Stratosfeer winter 2019/2020
Paul
Re: Stratosfeer winter 2019/2020
Bericht door Paul » 25-01-2020 08:20
De kaarten beginnen geleidelijk aan interessant te worden.
Voor het eerst negatieve zonale wind hoger in de stratosfeer.
Op 10 hPa redelijk sterke daling van de zonale wind en hieraan gekoppeld opwarming van de stratosfeer.
Over 10 dagen is bij het ECMWF nog weinig te merken van een eventuele verandering.
Toch is het laatste kaartje van GFS wel leuk om te plaatsen, als referentie maar vooralsnog met weinig waarde.
Als deze trend doorzet kan dit later in februari wel gevolgen gaan hebben voor de TPV.
Veel voorbehoud...
Bericht door Sebastiaan » 25-01-2020 10:53
2018 case study
https://agupubs.onlinelibrary.wiley.com ... 18JD028908
A major stratospheric sudden warming (SSW) event was observed in February 2018 after a 4‐year absence since the winter of 2013/2014. Based on the reanalysis data, the polar night jet changed from a very strong state to a moderate state during 12–19 January, and the moderate westerlies directly reversed to easterlies during 5–15 February. The intensified East Asian trough, Alaskan blocking, and East U.S. trough amplified the extratropical climatological wave 2, which propagated upward into the stratosphere, leading to a vortex‐splitting SSW event. Predictions of the February 2018 SSW event are explored in hindcasts initialized 0–4 weeks in advance by the Beijing Climate Center Climate System Model. Less than 20% of the 28 ensemble members predict the reversal of 60°N, 10hPa in hindcasts initialized 3 or 4 weeks in advance if a 5‐day error is allowed, while this ratio increases to 43% in hindcasts initialized 1 week in advance. Based on the climatological occurrence of SSW events in the forecast system, the maximum deterministic predictable limit of this event is 1–2 weeks in this forecast system. The eddy heat flux and its domination by wave 2 can only be predicted within the predictable time limit. A comparison between hindcast members initialized 2 weeks in advance suggests that the extratropical troughs and blockings are responsible for the upward propagation of waves from the troposphere to the stratosphere. The predictable limit of the stratospheric circulation pattern for the February 2018 SSW, 1–2 weeks, also generalizes to other vortex split SSW events such as the January 2009 and February 1999 cases.
Laatst gewijzigd door Sebastiaan op 25-01-2020 11:32, 1 keer totaal gewijzigd.
Bericht door Sebastiaan » 25-01-2020 10:58
Uitdraai van 0u-run. Je ziet een mogelijke split, waarbij een deel dan boven N-A zou komen en een ander deel boven Siberië. En dus niet boven de Atl. Oceaan, dit biedt een vergrote kans op winterweer bij ons.
Bericht door Sebastiaan » 25-01-2020 11:00
SSW-split or split developing:
- GFS00: 6 (11 has split or develops split)
- EC-split: 10 split (24 has split or develops split)
Still not confirmed: 10-12 days in all ens (GFS+EC) but we are closer
http://twitter.com/TradeWpower/status/1 ... 0911480835
Bericht door Sebastiaan » 25-01-2020 11:01
Bericht door Karel » 25-01-2020 11:35
Interessante ontwikkelingen in de stratosfeer verwacht. De datum van de oostelijke wind op 60N op 10hPa is iets vroeger dan in 2018.
De ligging van de split is nog erg onzeker. Voor tijden van vorige splits en de modelprestaties in 2018 zie:https://agupubs.onlinelibrary.wiley.com ... /grl.50927, http://www.s2sprediction.net/file/docum ... 081091.pdf, https://agupubs.onlinelibrary.wiley.com ... 091-SI.pdf
Bericht door Sebastiaan » 25-01-2020 14:31
Paul schreef:
23-01-2020 13:11
Henk schreef:
23-01-2020 12:42
Mijn vraag is: waarom is de stratosfeer momenteel zo koud? We komen toch van een lichte el Nino-situatie en dat zou toch implementeren een iets warmere stratosfeer. Verder is het tekort aan ozon in de stratosfeer duidelijk minder dan voorgaande jaren. Ook dat betekent toch een relatieve stijging van de temps in de stratosfeer. De enige verklaring zou kunnen zijn het diepe solar minimum van deze winter. Daardoor in de tropen minder ozon aanmaak. Wel, in vergelijking met de tropen, dan relatief meer ozon in de stratosferische noordpool, maar dat laatste alleen in relatieve zin. In absolute zin wellicht ook minder ozon in de stratosfeer boven de noordpool.
Maar dat is zo maar een suggestie.
Een 2 e vraag is waarom de koppeling tussen de stratosfeer en de troposfeer nu wel lukt (voor ons in negatieve zin) en vorig jaar februari niet. Jullie weten nog dat toen een koude golf werd verwacht i.v.m. stratosferische opwarming tussen 9 en 23 februari met bij ons een verwachte koudegolf. I.t.t.daarvan kregen we lenteweer. Een oorzaak zou kunnen zijn dat de QBO momenteel oost is met daardoor een betere koppeling.
Maar ook dat is een suggestie mijnerzijds.
Ik probeer een paar punten aan te geven die kunnen helpen met de beantwoording van jouw vragen.
Waarom is de stratosfeer zo koud?
We komen uit een periode met westelijke QBO, tot en met december. Dat, in combinatie met de geringe zonneactiviteit, is ongunstig voor stratosferische opwarming.
Er is echter ook een troposferische oorzaak aan te wijzen. Vanwege de positieve IOD (Indian Ocea Dipole) werd de NAO positief. In de herfst bleef deze lange tijd negatief, ondanks de IOD, maar begin december, op het moment dat de stratosfeer substantieel was afgekoeld en de SPV van invloed kon gaan worden op de troposfeer, sloeg de balans door.
Eenmaal in de positieve fase bewerkstelligde de NAO een gesloten troposferische poolwervel, die op zijn beurt versterkte weer de SPV.
Hieraan voorafgaand hadden we dankzij een sterk Russisch hoog nog een sterke wave1, eind november, met een Canadian Warming als resultaat. Die bracht geen winterweer, vanwege de IOD en was tegelijk contraproductief voor verdere stratosferische opwarmingen omdat hierdoor het Russische hoog aangetast werd.
Wat betreft de tweede vraag: koppeling tussen de SPV en de TPV is default, omdat ze elkaar wederzijds versterken. Andersom: een stratosferische opwarming remt weliswaar de TPV, maar als deze te sterk ontwikkeld is, zijn de effecten gering. Dat was vorig jaar het probleem, waardoor er minder dan verwachte doorwerking was. Daarbij speelde de inzettende positieve QBO ook een rol. We ondervinden dus dubbel nadeel van de positieve QBO, vorig jaar en dit jaar.
Dit zijn globale beschouwingen, de zeer sterke koude piek rond de jaarwisseling heeft een meer specifieke uitleg nodig.
Volgend jaar is de QBO negatief :D .
Ik zou nog willen toevoegen dat 1) door AGW koelt de stratosfeer op, een recordlage temperatuur is dus volstrekt logisch. 2) IOD voorkwam dat de MJO enige kracht kreeg, bleef hangen, dat kun je ook goed zien in het MJO plaatje (te vinden bij BOM) voor december. 3) Daarnaast deed MV de suggestie dat het geen echte MJO was. Dat begreep ik niet helemaal.
Over de IOD is hier e.e.a te lezen.
https://www.sciencedirect.com/topics/ea ... ean-dipole
Bericht door Gerben » 25-01-2020 18:06
Stratosfeer is zo koud omdat het "Siberisch" hoog veel te zuidelijk lag. Troposfeer staat dan geen energie af aan de stratosfeer. Dat lijkt nu te gaan veranderen. Weliswaar te laat maar ik verwacht vanaf 10/15 februari een meer winters weertype voor onze streken. Het wordt iig wat spannender
Henk
Bericht door Henk » 25-01-2020 20:33
Ja, dat laatste verwacht ik ook, Gerben.
Dank voor je reactie, Sebastiaan. Je schrijft dat door AGW de stratosfeer afkoelt. Vorige winter was de stratosfeer warmer dan gemiddeld. Verder zien we een warmere stratosfeer in de winters vanaf 2000.
