Bericht door Hans » 05-01-2020 18:02
Niet zo ver vooruit kijken.... Wordt je als winterliefhebber bijna depressief van. Ik niet hoor...
Want: ik houd het bij het moment. Bewolkt? Okay!
Zacht? Okay! Koud? Mooi en okay!
Het is wat het is....
Was vroeger altijd zo toen we nog geen technieken hadden om (ver) vooruit te kijken.
Zo ga ik persoonlijk met mijn weerhobby om.
En.... bevalt prima...
Bericht door Daniël » 05-01-2020 21:49
Op Netweather "When Will There Be Any Snow? Not Any Time Soon. Blame A Strong Polar Vortex" o.a. het volgende:
There was a change in the track of the jet stream just before Christmas, with a shift in the jet closer to the north of Britain, a change that has stuck ever since. This means most of the wind and rain since the change has been directed at northern and western areas, while southern, central and eastern areas that saw so much rain before Christmas have seen much less rain thanks to higher pressure.
The shift to a more northerly track in the jet stream can be attributed to a suddenly flip in the Arctic Oscilation (AO) in late December.
The AO's positive phase is characterised by lower-than-average pressure over the Arctic paired with higher than average pressure over the north Pacific and north Atlantic oceans, this leads to a jet stream that is further north than average, leading a more northerly storm track over both oceans. While the negative phase is the reverse of the positive phase, with higher-than-average pressure over the Arctic and lower-than-average over the northern parts of Pacific and Atlantic oceans.
Through much of November and mid-to-late December, the AO was in neutral to negative phase, then just before the New Year the AO flipped from negative to positive in the space of a few days, the AO indices going from -2.5 to +3.5C around New Year's Day.
The change can be attribued to a strong Polar Vortex sat over arctic vertically stacked through the troposphere (where our weather is) and up through the stratosphere. The Polar Vortex is a column of very cold air that forms one big low pressure circulation in the atmosphere and keeps cold air bottled up in the high latitudes of the arctic while lower latidudes of United States (Canada mostly cold) and Europe stay mild. The Polar Vortex was already strong at the start of winter in the stratopshere, but started to couple with the troposphere lower down, where our weather takes place, as December progressed.
Bron: https://www.netweather.tv/weather-forec ... lar-vortex
Dus bij een sterk positieve AO-index heb je dan een noordelijk gelegen straalstroom en daardoor dus van die hardnekkige Eurohogen boven het Europese vasteland.
Bericht door Johan » 06-01-2020 00:00
Allemaal goed & wel ! Maar hoe gaat het dan verder ? Er wordt niets gezegd over januari, februari & zelfs maart... Wordt die AO alsnog neutraal tot negatief...? Ik hoorde zoiets enkele dagen geleden voor de tweede januarihelft zelfs... Of heb ik het mis...?
Bericht door Daniël » 06-01-2020 12:47
Gelukkig toch de 30-daagse op weer.nl. "30-daagse verwachting: winter valt nog niet in". Volgens deze 30-daagse blijven wij met een zeer hardnekkig hogedrukgebied te maken.
Bericht door Ted » 06-01-2020 13:15
Laatst gewijzigd door Ted op 13-02-2021 20:07, 1 keer totaal gewijzigd.
Bericht door John » 06-01-2020 17:43
Daniël schreef:
06-01-2020 12:47
Je hebt gelijk, Daniël, deze is meer gedetailleerd ten opzichte van Weerplaza.
Ik zou het woordje nog weglaten, dat wekt te veel suggestie. :mrgreen:
Gewoon 30-daagse: winter valt niet in.
Bericht door Pieter » 06-01-2020 21:53
Ik begin mij af te vragen; Is het nog ergens koud op deze aardbol ? Ook in de VS is nauwelijks winterweer te vinden, gelukkig is het in Yakutsk (Siberie) de komende dagen( naar verwachting) tussen de -24C en -42 C ,dit is voor Siberie niet extreem , maar wel heeeellll KOUD
Bericht door Vincent » 06-01-2020 22:28
Dat heet daar toch echt "zacht winterweer". 8-) :lol:
Bericht door Ted » 06-01-2020 22:51
Bericht door Ko » 06-01-2020 23:10
Ik denk dat nu de aarde naar de knoppen is. We hebben nu het punt bereikt dat het niet meer afkoelt.
Kan me nog herinneren dat het in winter 1989 en 1990 ook op grote schaal extreem zacht was. Ook in de wintersportgebieden lag toen geen sneeuw. Daarna kwam nog gewoon winter + koud jaar 1996 en Elfstedenwinter 1997.
Ook na de serie zeer zachte winters 1998 - 2008 verschenen er ineens vijf koudere sneeuwwinters op rij met geheel koud jaar 2010. Sinds 2014 weer een serie zachte winters. Het zijn gewoon schommelingen die er altijd al waren.
