The schreef:It is too early for a clear signal for winter 2018/19 to emerge. Recent climatology favours milder conditions but some of the background signals and the increased propensity for high pressure blocking to form since the Sudden Stratospheric Warming (SSW) event in February suggest otherwise.
At this stage the TWO view continues to be that there is an increased chance of winter 2018/19 being close to or colder than average.
Winter 2019
Re: Winter 2019
Op https://www.theweatheroutlook.com/twoother/twocontent.aspx?type=hpnews&id=4508&title=UK+winter+2018%2f19 " UK winter 2018/19 Update 2":
Laatst gewijzigd door Daniël op 24-09-2018 18:38, 1 keer totaal gewijzigd.
Re: Winter 2019
http://agupubs.onlinelibrary.wiley.com/doi/pdf/10.1029/2018GL078838
Dat het compleet zinloos is, is niet waar. Alleen je dient wel te weten waar je op moeten letten en welke beperkingen er zijn.
Uit deze studie (aanrader om hem helemaal te lezen!) blijkt flinke afwijkingen van de NAO, zowel positief als negatief goed te voorspellen zijn.
Recent studies of individual seasonal forecast systems have shown that the wintertime North Atlantic Oscillation (NAO) can be skillfully forecast. However, it has also been suggested that these skillful forecasts tend to be underconfident, meaning that there is too high a proportion of unpredictable noise in the forecasts. We assess the skill and overconfidence/underconfidence of the seasonal forecast systems contributing to the EUROpean Seasonal to Interannual Prediction (EUROSIP) multimodel ensemble system. Five of the seven systems studied have significant skill for forecasting the wintertime NAO at 2‐ to 4‐month lead times. Four of these skillful systems are underconfident for forecasting the NAO. A multimodel ensemble (ensemble size 126 members) is both skillful and clearly underconfident. Underconfidence becomes more pronounced as the ensemble size increases. Certain years in the hindcast period are well forecast by all or most models. This implies that common teleconnections and drivers of the NAO are being captured by the EUROSIP seasonal forecasts.
Plain Language Summary
In this paper we provide an intercomparison of seven seasonal forecast systems, with particular focus on the wintertime North Atlantic Oscillation (NAO). The wintertime NAO is the main driver of winter weather variability in the United Kingdom and Europe, and being able to forecast the NAO for the season ahead has potential benefits for many different sectors such as agriculture, energy, health, transport, and water resource management. We show that five of the seven systems studied can skillfully forecast the NAO, and a multimodel ensemble has even higher skill. Four of these skillful systems are found to be underconfident, which means that there is too high a proportion of unpredictable noise in the model. Being underconfident makes it more difficult to fully utilize the skill of a forecast. However, one system is skillful but not underconfident. We also find that there are common years in which the NAO is well forecast by all the skillful systems. This is an important result because it implies that common drivers of NAO predictability are being captured by these systems. These results are an important contribution to our understanding of seasonal forecasts systems and the predictability of the NAO.
Re: Winter 2019
Het winterdrama in beeld.
Re: Winter 2019
Op https://wintersportweerman.nl/fletse-zon-en-koud-atlantisch-water-voorbode-van-serie-koudere-winters-105571/ "Fletse zon en koud Atlantisch water voorbode van serie koudere winters".
Re: Winter 2019
http://twitter.com/WorldClimateSvc/status/1047840587368546305
The latest CanSIPS winter forecast has eliminated the ridge over northern Europe and now shows high pressure west of the British Isles (mostly in February). Unfortunately skill at this lead time is essentially zero for the European sector according to 30 years of hindcasts
Re: Winter 2019
MG zegt er ook iets over de winter van 2019
Welke parameters gaan de winterverwachting in?
In de huidige weerdynamiek lijkt de komende weken dus nog weinig te veranderen. Ondertussen wordt er al gewerkt aan de seizoensverwachting voor komende winter. Deze prognoses worden steeds betrouwbaarder, al zijn ze al een tweetal decennia ‘experimenteel’. Voor het opstellen ervan wordt een bijna onuitputtelijke hoeveelheid informatie ingezet. Zeewatertemperaturen, de omvang van het poolijs, het al dan niet optreden van een El Niño, de zonnevlekkencyclus, het orkaanseizoen, de ozonlaag, etc etc.
Vervolgens zijn er eigenlijk twee manieren waarmee de uiteindelijke verwachting tot stand komt. Er wordt gewerkt op statistische en dynamische grondslagen. De eerste gaat over het cijfermatig vergelijken van allerlei optredende omstandigheden. Je kunt bijvoorbeeld kijken naar het optreden van een La Niña en de cijfers op een rij zetten wat er in die periode weertechnisch gebeurde in West-Europa. Of, je vergelijkt de activiteit van het Atlantische orkaanseizoen met de Europese luchtdrukverdeling in de navolgende decembermaand. Daar kan een bepaalde consistentie uit naar voren komen. Als je dat van heel veel omstandigheden doet, zijn daar een soort van conclusies uit te trekken.
De dynamische grondslagen gaan veel meer over oorzaken en direct te koppelen gevolgen. Denk aan bovenmatig warm zeewater dat bij een aanlandige wind de temperaturen hoger zal houden dan normaal. Of dat afkoeling boven land gemakkelijk tot een hogedrukgebied kan leiden. Ook op grotere schaal zijn er al vrij veel natuurkundige koppelingen duidelijk geworden in de afgelopen jaren. Zo kijkt men bij de World Climate Service uitgebreid naar de zeewatertemperaturen. Afbeelding 4 toont de afwijkingen van dit moment. De warme en koude plekken op de noordelijke Atlantische Oceaan geven indicaties van waar hoge- en lagedrukgebieden bij voorkeur komen te liggen.
Later dit herfstseizoen volgen we met enkele details over de verwachtingen voor de naderende wintermaanden. Daar wordt nu nog hard aan gewerkt.
Met de koude en warme plekken op de noordelijke Atl. Oceaan verwijzen ze naar een positieve NAO. Glosea5 kwam daar ook mee. Iets wat we niet zomaar kunnen negeren. Het ziet er vooralsnog niet goed uit.
Laatst gewijzigd door Sebastiaan op 05-10-2018 11:13, 1 keer totaal gewijzigd.
Re: Winter 2019
Van de week komen de laatste uitdraaien van EC, Glosea5 en JAMSTEC beschikbaar. Benieuwd.
Re: Winter 2019
Sebastiaan schreef:Met de koude en warme plekken op de noordelijke Atl. Oceaan verwijzen ze naar een positieve NAO. Glosea5 kwam daar ook mee. Iets wat we niet zomaar kunnen negeren. Het ziet er vooralsnog niet goed uit.
Een positieve NAO zou dan bij ons een zachte en een natte winter betekenen. Daarmee zou de huidige aanhoudende droogte dan eindelijk ook goed weggewerkt kunnen worden.
Re: Winter 2019
Ja klopt. Gemiddeld gezien heeft een positieve NAO een hogere temperatuur dan normaal tot gevolg. Ik vermoed ook natter dan volgens de norm.
Re: Winter 2019
Sebastiaan schreef:Ja klopt. Gemiddeld gezien heeft een positieve NAO een hogere temperatuur dan normaal tot gevolg. Ik vermoed ook natter dan volgens de norm.
Ik zag zojuist de nieuwe uitdraai van EC. De januarikoude is van de kaart.
Het wordt rustgevend winterweer, want geen hoge verwachtingen.
Afhankelijk van het Azorenhoog kan een positieve NAO ook prima met te droog weer gepaard gaan.
We hebben de anticylonale circulatie uit zuidwest, west of noordwest.
Laatst gewijzigd door John op 08-10-2018 17:52, 1 keer totaal gewijzigd.
