Stratosfeer herfst 2017
Re: Stratosfeer herfst 2017
The relatively quiet WAFz, the strengthening stratospheric PV and the positive stratospheric AO suggest that in the coming weeks the circulation pattern in the stratosphere could couple to the troposphere leading to a period of a positive tropospheric AO, mostly zonal flow and relatively mild conditions across the NH mid-latitude continents. I consider this the most likely stratospheric-tropospheric coupling in the next 30-days. The PCH plot does suggest the tropospheric PCHs will warm in mid-November, signaling a turn to colder weather across the continents most likely across Eurasia. This could also set up more active poleward heat flux and a weakening of the stratospheric PV. I am skeptical of the timing of this scenario as suggested by the GFS PCH forecast, however I do expect this set of events to occur if not in November then in December. http://www.aer.com/science-research/climate-weather/arctic-oscillation
Eurasian snow cover extent will finish above normal for the month of October. It started the month with well above normal snow cover extent (SCE) but then had a fairly unusual stall where the snow cover extent nearly didn’t advance for two whole weeks. This was an unprecedented event in recent Octobers. However, in the third week of October the snow cover extent picked up once again and October 2017 SCE will easily be above normal and given how the month began was never really in doubt.
Besides SCE an alternative snow index that I have proposed and utilize in subseasonal to seasonal forecasts is the snow advance index (SAI). The SAI does not measure the areal extent of snow cover but rather the rate at which the snow cover advances over the course of the month and the area measured is limited to equatorward or south of 60°N. A relatively rapid advance of snow cover would be comparable to extensive snow cover and an indication for a weak polar vortex (PV), a negative AO first in the stratosphere followed by a negative AO in the troposphere and relatively cold weather across the Northern Hemisphere (NH) mid-latitudes. Given the long stall in snow cover advance in mid-October, the SAI will likely be negative this October. This is a forecast of a strong PV, a positive AO in both the stratosphere and troposphere and a relatively mild winter across the NH.
The SAI index is in contrast to the SCE index that indicates just the opposite. This is a similar situation to 2013 when the SCE was strongly positive and the SAI was negative. This adds complexity and decreases my confidence in the winter forecast. I have come to believe that the SAI is most useful as an indicator of the timing of when we might expect a weakening the stratospheric PV. When the SAI is positive then we can expect a stratospheric PV weakening earlier in the season and when the SAI is negative then we can expect any weakening of the stratospheric PV to take place later in the season. In 2009 and 2016 when the highest SAI values have been observed since daily snow cover extent has been available, stratospheric PV weakenings were observed even before the winter began with an unprecedently early PV split observed at the end of October and early November last year. There are so far no signs of a robust stratospheric PV weakening and indications are even for a relatively strong stratospheric PV for much of the month of November. Similarly in fall and early winter 2013/14 the stratospheric PV was strong but eventually troposphere-stratosphere coupling became active that did not result in a strong PV weakening (no major mid-winter warmings were observed that winter) but did stretch or repeatedly elongated the stratospheric PV that contributed to a cold winter in the Eastern US.
http://ionlyusethegfs.blogspot.nl/2012/04/qbo-aleutian-high-relationship.html?m=1
Interessante bijdrage van Anthony Masiello.
Tot nu toe bleef de stratosfeer dicht bij het gemiddelde. Maar de komende tijd zien we waarschijnlijk (altijd afwachten natuurlijk, zodra het over de toekomst gaat) een intensivering van de stratosferische poolwervel. 'We' komen als de berekeningen van GFS kloppen, in dit gedeelte van de atmosfeer is de betrouwbare voorspellingstermijn wat verder weg, duidelijk boven de normaal. Een zonaal patroon voor november. Ja, ik vermoed van wel. Koppeling is niet altijd 1 op 1. Dus geen garanties. Ook afh. van ontwikkelingen verder in de maand.
De intensivering van de stratosferishe poolwervel richting december is normaal. Zolang er warme impulsen komen vanuit Siberië zoals in de berekeningen van ECMWF dan is het gewoon afwachten tot eind december. Timing is essentieel zoals vorig jaar is gebleken. Met nu QBOE is aan een gunstige voorwaarde voldaan. De extratropische circulatie moet blijven meewerken in december.
Laatst gewijzigd door Karel op 01-11-2017 14:53, 1 keer totaal gewijzigd.
Afwachten tot eind december? Wachten waarop?
Laatst gewijzigd door John op 01-11-2017 19:41, 1 keer totaal gewijzigd.
De bus
Ik denk dat Karel bedoelt van wat er gaat gebeuren. Zeer weinig kans op een SSW tot die tijd sowieso.
Een beredeneerde winterverwachting.
http://raleighwx.americanwx.com/research/Winter2017-18Forecast.pdf
Bedankt Sebastiaan.
Inderdaad alles op een rij met nadruk op de USA.
De sleutel voor de komende winter ligt voor ons gebied in de ontwikkeling van de North Atlantic Oscillation en het Eastern Atlantic Pattern de komende maanden. Dat is nu nog niet bekend en ook niet voorspelbaar.
Overigens hebben we in Nederland gemiddeld nu eenmaal meer te zachte dan te koude winters.
Laatst gewijzigd door Karel op 01-11-2017 20:37, 1 keer totaal gewijzigd.
Ok. Dat is duidelijk nu.
Gelukkig zijn we nog niet zover dat we daarmee elke vorm van winterweer de komende 9 weken uitsluiten.
Althans ik ben nog niet zover, jullie misschien al wel.
